Best Spot Through Firewall??
Old Jun 24, 2005 | 02:53 PM
lokee99's Avatar
I'm stock and hating it.
I am having a very hard time trying to figure out the best place to run my amp's power wire through the firewall. Maybe some of you DIY people can help me out. I have checked the audio and video threads but nothing that can help me. Thanks for some help.
Old Jun 24, 2005 | 03:08 PM
demolition_x's Avatar
Agean Blue Bishes
right above the pedals there is a spot. i ran 4 gauge with no problem
Old Jun 24, 2005 | 03:37 PM
Pure Adrenaline's Avatar
Dragging knees in
Right above the pedals, there's a circular shaped plug. Pops it out, shine a light through it, and locate it from the engine bay. This is how I ran the wires for my EDFC.
Old Jun 24, 2005 | 06:58 PM
SC2.2CL's Avatar
So do you have to push a hole in the fire wall. I tried to get the wire through, but it was filled. I did not want to break anything so I ran the wire through the window controlls hole in the driver side wheel well. Should I just take a screwdriver and punch a hole though about the gas pedal?
Old Jun 24, 2005 | 07:26 PM
Agean Blue Bishes
yea stick an ice pick then keep going bigger until the wire slides through. you have to put a hole in it.
Old Jun 24, 2005 | 10:30 PM
SwampGas's Avatar
/etc/car
Be VERY careful of wires already there. When I punched my amp wire through the grommet above the e-brake, the screwdriver must have scraped a wire bare and it shorted. For some reason all of my fuses are fine but the turn signals no longer blink when arming/disarming the car.
Old Jun 26, 2005 | 01:11 PM
lokee99's Avatar
I dont see any other wires coming out of the one above the gas pedal.
Old Jun 26, 2005 | 09:56 PM
Dragging knees in
The hole above the pedals is a dead hole. There's nothing going through it. But you do have the get the plug out in order to use it.
Since it connects the engine bay the cabin together, I would recommend stuffing it with some cotton balls or something once you are done putting the wires through.
Old Jun 30, 2005 | 12:10 PM
lokee99's Avatar
Thanx all. The one above the gas pedal I think is the best. It was a lot easier than I thought. Got it all hooked up and ready to go.
Old Jun 30, 2005 | 01:19 PM
fsttyms1's Avatar
there is also one under the mastercyl that you can use. its harder but a i got a 4gauge thru the gromet
ITSJESTER
17
Dec 6, 2018 02:29 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
