best spot to jack thecar up from?
Agean Blue Bishes
1 Post
i hate jacking the car from the tabs on the side of the car. i hate the thought of one of those breaking off and my floor caving in.
i remember some one said theres a point in front of the car where you can jack the whole front up?
Chloe @ 17mo
If my car weren't so low, I would use a hydraulic jack under the front frame support. So, I use the oem jack and jacked it up from the side, insert the hydraulics and lift it up. You could do the same.
/etc/car
I don't think you're going to break off a vertical support structure welded to the frame unless there's serious deterioration from rust or damage.
There's also a jack point around the center under the engine. Good for putting it on jack stands (or cinder blocks if you're ghetto like me).
Yes there is a lift point in the dead center of the car around the area of the radiator. I would only lift from there if you have a big enough lift pad on the jack.
Tristate Vip Crew
I think I have spent as much if not more money on tools for my car then mods. My car is also lowered. I purchased a low profile hydraulic jack at sam's club, cost me about 120 bucks. Works great!!!
ITSJESTER
17
12-06-2018 02:29 AM
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
