Best spark plug?
Old Aug 11, 2013 | 09:13 AM
Nemesis TL-S's Avatar
Best spark plug?
What is the best spark plug to use for the 03 TL-S? I see a couple of NGK and other brands but I don't know what's the best and why?
can Anyone help?
Old Aug 11, 2013 | 09:20 AM
stock is the best. the NGK's
Old Aug 11, 2013 | 10:46 AM
3.2TLc's Avatar
Yeah, as Justnspace said...."NGK's" are the best choice.
The newer Iridium NGK's are ok to use also, if desired.
Old Aug 11, 2013 | 02:49 PM
I don't understand the differences in the NGK plugs. There are Iridium, Laser Platinum and G-Power. All of them fit our car. Which one is the OEM? Is one better than the OEM?
Old Aug 11, 2013 | 03:01 PM
tlmane03's Avatar
most go with iridium and seem to enjoy
Old Aug 11, 2013 | 03:19 PM
Skirmich's Avatar
Ill help you on that...
NGK G-Power = Value plug = CRAP < If your getting G-Power for the TL, You might as well get Fram filters.
NGK Platinum = Platinum Tip, Steel Ground.
NGK Double Platinum = OEM 2G (To Cut Maintenance Cost) = Platinum Tip, Platinum Ground.
NGK Iridium IX = OEM 1G/3G/4G = Upgrade for 2G (Should have been the OEM) = Iridium Tip, Platinum Ground
(RACING) NGK Laser Platinum = Super Upgrade = Platinum Tip, Platinum Ground on a Forged Plug.
(RACING) NGK Laser Iridium = Ultimate = Iridium Tip, Iridium Ground on a Forged Plug.
Old Aug 11, 2013 | 08:46 PM
Type-ES's Avatar
Just go for the laser iridium. Yeah they are about 10 bucks a plug but hey, if your engine is running fine you'll (probably) never have to change them again.
Old Aug 12, 2013 | 05:42 PM
TLer trash's Avatar
With all due respect, you've got quite a bit of this wrong:
NGK V-POWER: Conventional resistor spark plug.
NGK G-POWER: Fine wire platinum center electrode, conventional side electrode.
NGK Iridium IX: Fine wire iridium center electrode, side electrode doesn't have any platinum or iridium, but the end is a blunted v-shape instead of square.
NGK Laser platinum: Fine wire platinum center electrode, platinum pad on side electrode.
NGK Laser iridium: Fine wire iridium center electrode, platinum pad on side electrode.
The Iridium IX was not oe on any honda product as far as I know.
1G and 2G came with laser platinum, 3g came with laser iridium.
Of the listed plugs, only the laser platinum and laser iridium are considered long life plugs.
It's generally accepted that conventional plugs are good for about 30k miles, single platinum or iridium, 60k miles, and double platinum or iridium, 100k-120k miles.
xx
Old Aug 12, 2013 | 06:38 PM
tlmane03's Avatar
do you feel your question was answered ts?
Mike734
Dec 10, 2021 01:25 PM
acuratl26
Apr 23, 2020 07:30 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
