Best site to Order Cold Cathodes from????
99TL-p 114K
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
What is the best site for me to order cold cathodes from?? I want to mount some in the front footwells. Anyone who has already done this would be a big help for me???
www.case-mod.com cheapest and the best, fast shipping as well. they sometimes sell out fast of the popular colors and it'll just take a few days to stock more
99TL-p 114K
Originally Posted by Bxscig
www.case-mod.com cheapest and the best, fast shipping as well. they sometimes sell out fast of the popular colors and it'll just take a few days to stock more ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
slobalt defender
I used Oznium.com, I have footwell, trunk, under seat, and back window cathodes all wired to a switch box in my center console. They ship really fast.
PM me and i'll go into detail about installation, took about 4 hours for me.
I LOVE LLAMAS
NOOOOO... DO NOT HOOK UP ANY CATHODES TO ANY DIMMING DEVICE, SURE IT LOOKS COOL, but lower voltage over time, say a week, = BLOWN TRANSFORMER, any dimming device slow or quick will blow a transformer, which in turn will blow a fuse.......
99TL-p 114K
What do i need to do then?
Originally Posted by dvsxlt247
Ok, sounds good. Im doin white since i have super white PIAA LED's in the maps, doors, trunk, license plate and dome. Have you installed cold cathodes yourself already?? If so, is it very easy to wire it up to the cars dome light so that they come on when you open the door and fade out once its closed?? Will wiring it that way cause my dome light to stop working over time because i have heard about that happening before to someone else. What all will i need for the install?
Yeah they fade with the dome lights and I had no problems unlike what others have said. I had them in my car for over 18 months. I've installed it for other people as well for well over a year I believe and no issues. All hooked up to the dome light. Only bad thing was that these cathodes are definitely more delicate than regular neons. So hiding it on the passenger side is a LITTLE harder. I have 3 sets of 2 installed in my trunk. I did the rear as well but didnt spend much time fixing it. People ended up breaking 2 sets so I just removed it from the rear seats. I used white myself. My brother with a RSX-S is using red since it matches his dash and interior colors.
I dont know if the fading due to lower voltage drop will cause it to blow but I havent had it happen. Maybe it will in 2 years time but it will still last a damn long time
99TL-p 114K
Only from personal experience and the other people I installed it for. I had it running in my car the longest.
I also have ccfl, had it for about 18 months also. Got no problem with it and never heard of it going out. If it does, it is not expensive to replace it at all.
The passenger side is a little more difficult, you can use double sided tape and have it stick on the bottom end of the glove compartment if you get it in the right area. Or you can just zip tie it to something/ wire. Just play with what you got a little bit and you will find a way.
Drivers side is definately easy, nothing to worry about there.
Like what Bxscig said, becareful with the rear, my passengers ALWAYS have a habbit of breaking them.
BTW, does anybody know if there is a fuse for the trunk light? My ccfl went out in my trunk and now i have no power to it.
P.S. I don't know about you guys, but when i extended my wires the first time, I used a gauge that was to big and had not enough power to them (half lit up bar and no light what so ever. I recommend you not using anything lower then 16 gauge I think it was.
Good Luck with the install
It is smaller and easier to hide but still harder on the passenger side. I stuck it in the little gap where the glove back opens up. Right in front of where the cabin air filter is. It just fits in there and is safe when I open the glove box. Test to make sure you put it high enough in there so that is safe when you open the glove box.
