Best place to buy 19mm lug nuts?
TL ftw!
My lug nuts are too big for the rims I bought, I was very disappointed when I waited 1 hour then when it was my car's turn they said the lug nuts are too big and they didn't have any in stock and it would take 3 days. Plus they were $74.50 for the 20 piece set. I was like
. Anyone know the best place? By the way I went to PepBoys.
![Yuck](https://acurazine.com/forums/images/smilies/yuck.gif)
In 702, 808 in Dreams
nope. our TLs. are 19mm. i hope when everyone changes there wheels on here are not using the OEM lugs?? because if you are you need to change them asap with aftermarket wheels unless you are running ron jons. reason being OEM is ball seat style wheels and lug nuts. aftermarket is acorn style. the ball seat will not have enough surface contact with the acorn style wheels and this will become loose after driving. anyone with aftermarket wheels need to switch to acorn style lug nuts.
KamikazeTL. - for that price you can pick up almost Rays lug nuts. check on honda-tech and see if you can pick up the meuteki or kyokugen lug nuts for like $50 or less. i am running the kyukugen lugs on my racing harts. they are suppose to be light weight to reduce unsprung mass. i know the meuteki lugs you can get them in open and closed end. depends on which style wheel. i hope this helps. and dont use OEM LUGs on aftermarket wheels unless its custom like ron jons with ball seat machined seats..
Originally Posted by PenancE
so 12x1.5 isnt good for stock rims like a type s? i just want to get blue ones to match the paint..
nanos
11-12-2015 08:41 PM
