BC Motor Vehicle Act concerning blinkers, etc
Folks:
I dug up some info concerning issues with legalese on the corner blinkers. Here's what i found for BC. We can have either WHITE or AMBER turn signals on the front. As for reflectors, i've also included the code here, but i'm not clear on what "width"means. Does it mean how long the car is, meaning its "length", or how wide the car is in the front. Anyway, i think it's best to leave the yellow reflective patch in the front, unless someone can interpret lawyer talk below. Here's the full link:
http://www.qp.gov.bc.ca/statreg/reg/...tm#section4-01
MOTOR VEHICLE ACT REGULATIONS —
B.C. Reg. 26/58
Turn signal devices
4.13 (1) A vehicle may be equipped and mounted with
(a) a lamp type turn signal system, or
(b) a semaphore turn signal device,
functionally equivalent to original equipment supplied by the vehicle manufacturer or of a type or make approved by the Insurance Corporation of British Columbia.
(2) A lamp type turn signal system must
(a) have 2 lamps, mounted on the front of the vehicle, that are capable of displaying flashes of white or amber light which are visible to the front,
(b) have 2 lamps, mounted on the rear of the vehicle, that are capable of displaying flashes of red or amber light which are visible to the rear,
(c) be visible on each side of the vehicle at a distance of 100 m in normal sunlight at an angle of 45° from the longitudinal axis of the vehicle, and
(d) include a tell-tale lamp which gives a clear indication that the system is activated.
(3) During the time specified in section 4.01, a semaphore turn signal device must be capable of illumination by light or reflection visible from a distance of 100 m.
(4) A public passenger vehicle or a commercial vehicle that weighs more than 4 500 kg may be equipped with supplementary turn signal lamps in addition to the turn signal system required by subsection (2).
(5) A turn signal lamp must be mounted on the vehicle at a height of not less than 38 cm and not more than 1.83 m.
(6) Subsection (5) does not apply to highway construction vehicles, maintenance vehicles, tow cars or vehicles being towed by a tow car.
(7) A vehicle which is being transported in a drive-away/tow-away operation, or is being towed by a tow car, must have turn signals that are synchronized with the turn signals of the towing vehicle when the tow vehicle turn signals are illuminated.
(8) Despite subsection (5), a tow car may be equipped with supplementary turn signal lamps mounted within the maximum allowable vehicle height (4.15 m) and as far forward as the rear of the cab.
(9) The centre of the front signal lamps must be at least 10 cm from the edge of the low beam headlamps
[en. B.C. Reg. 476/98, s. 2.]
Reflective devices
4.21 (1) A vehicle must be equipped with at least one red reflector at the rear of the vehicle, either separate or incorporated into a tail lamp, that is mounted at a height of not less than 38 cm and not more than 1.83 m.
(2) Subsection (1) does not apply to a vehicle manufactured before January 1, 1958.
(3) Only amber reflectors may be mounted on the front or side of a vehicle.
(4) Only red reflectors may be mounted on the rear of a vehicle or on the side of the vehicle at or toward the rear of the vehicle.
(5) A vehicle with an overall width of 2.05 m or more, or a trailer or semitrailer having a gross weight in excess of 1 400 kg, must be equipped with at least
(a) 2 amber reflectors mounted on the side of the vehicle, trailer or semitrailer near the front,
(b) 2 amber reflectors mounted on the side of the vehicle, trailer or semitrailer near the rear, and
(c) 2 red reflectors mounted on the rear of the vehicle, trailer or semitrailer.
(6) A trailer or semitrailer must be equipped with at least one red reflector on the rear of the vehicle at each side.
(7) A pole trailer must be equipped with at least
(a) one amber reflector on each side of the vehicle at the front and the horizontal mid-point, and
(b) one red reflector on the rear of the vehicle or load at each side.
(8) A commercial trailer with a width of more than 2.05 m and a gross vehicle weight rating of more than 4 536 kg must be equipped with reflective markings on the rear and side of the vehicle to meet the approved standards established by the Motor Vehicle Safety Act (Canada) and the applicable SAE standards
(a) on and after January 1, 2000 if the vehicle was manufactured on or after December 1, 1993, and
(b) on and after January 1, 2002 if the vehicle was manufactured before December 1, 1993.
(9) Despite subsections (1) to (7), reflective markings may replace red or amber reflectors on the side or rear of a vehicle.
[en. B.C. Reg. 476/98, s. 2; am. B.C. Reg. 413/99.]
B.C. Reg. 26/58
Turn signal devices
Reflective devices
navtool.com
31
11-16-2015 08:30 PM
lanechanger
10-13-2015 10:56 AM
xsilverhawkx
09-28-2015 06:51 PM
