battery just died help
Old Jun 28, 2004 | 03:45 AM
bug230's Avatar
mushroom mushroom
Should I stick with stock or should I go with something else? I'm currently running a stock radio but I may upgrade to something to somthing that will run a 10in JW3 and upgraded door speakers. any sugestions?
Old Jun 28, 2004 | 04:48 AM
Seotaji's Avatar
your battery has nothing do with a stereo upgrade unless you run it when the car is off.
if the total amperage of your equipment excceds the stock rating of your alternator, then you will damage your alternator if you run stereo equipment without an upgrade.
get the stock battery and upgrade your alternator (if it needs it).
Old Jun 28, 2004 | 05:34 AM
kman156's Avatar
hey bug, oem batteries kick the bucket after 2 years!
especially in the HEAT, HEAT, HEAT!!! and it's hot out there!!! get yourself an optima yellow top gel-cell! no more dead batteries!!! then if you upgrade your alternator later you're set!!! i've had to replace the battery after 2 years in every honda/acura ( only cars i've had since 88! ) whattya gonna do?
Old Jun 28, 2004 | 07:58 AM
orcaatk's Avatar
I replaced mine with a Diehard Gold.... If it dies in the next 5 years, I get another one free.
Old Jun 28, 2004 | 09:33 AM
VTEC11's Avatar
a free one? Dosn't sears pro-rate there battery and tire warranty?
Old Jun 28, 2004 | 09:49 AM
orcaatk's Avatar
Usually, yes, but my car just happened to die when Sears was running a promo on the gold series.
MetalGearTypeS
Aug 29, 2016 08:28 PM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
mars
Sep 28, 2015 11:03 AM
