Battery and Brake lamp on intermittently
I have an 2003 Acura TL Tyoe-S. About 5 months ago I cleaned the transmission filters on top and front of the trans. I recall that my negative battery was connected to these, but I am unsure if after the filter job was done if I reconnected the cable to the correct locations. Ever since then, I've had the brake/battery light come on and of course I'm draining my battery. I have the alternator tested since this began while the lights were out, and it came back ok. I am going to wiggle cables while idling to see if I can narrow down some loose bolt or bad connection. Can someone point me in the right direction with a picture of theirs or a reference as to where the proper grounding points for the charging system are?
JTS1
ILX Problems & Fixes
04-19-2023 05:12 PM
