Battery
Old Nov 16, 2011 | 05:22 PM
steve's Avatar
Battery
With Winter approaching, I had battery checked and was fine. It is a Group 25 Sears Gold Diehard installed exactly 5 yrs ago. With that age, does it make sense to just go ahead and replace it now? Seems this brand battery has been fine in all my cars but anyone have any other rec's?
Old Nov 16, 2011 | 06:29 PM
Karanx7's Avatar
Unregistered Member
Why change it with winter coming? They like the cold.
Batteries here in AZ don't last more than 3 years.
Old Nov 16, 2011 | 06:32 PM
01tl4tl's Avatar
it was ckd for fluid level, static volts, charging volts, cranking amps/recovery from cranking
on a machine? with numbers? at a parts store or shop?
5 years is awesome life from normal batts these days
3-4 is average
if its fine by all the test, dont sweat it right now
better to replace the battery cables and ground cable system for engine to frame
winter does put the hurt on batteries with more electrical draw for more hours each day, driving in longer darkness = lights, heat, seat heat, tunes on more,,thats a lot of amp draw
and the alternator must be able to replace all that use immediatly
Old Nov 16, 2011 | 09:09 PM
Edward'TLS's Avatar
6G TLX-S
If the battery has been load-tested ok, there is nothing to worry about.
MetalGearTypeS
Aug 29, 2016 08:28 PM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
steve
Sep 30, 2015 09:23 PM
mars
Sep 28, 2015 11:03 AM
jmaxima03
Sep 27, 2015 10:22 AM
