ballast?
Old May 8, 2011 | 08:44 AM
hondakid23's Avatar
ballast?
hey whats up people..i have a quick question i just bought a 2003 acura tl type s and my driverside headlight went out i was replaced my xenon lights and after i changed the bulb i turned on the lights to test if it was working an only the pax side does the driver side makes like a zap noise? I asked one of my friends because im unfamilar with this and he said it could be my ballast. The dealership sells it for 259$ can i find one cheaper??
thanks and hope i get some feedback
Old May 8, 2011 | 09:03 AM
Willie3.5's Avatar
SixSpeedDreamin'
Yea, you can definitely find cheaper ballast. I recommend replacing them both at the same time so you don't have to deal with replacing the other one down the road. There are several websites out there. theretrofitsource.com, hidconcept.com, and hidextra.com. I bought my 35W Morimotos from theretrofitsource.com and I am very impressed. I've had them for a month+ with no problems. I paid $110 for both ballast and the quality is superb.
Old May 8, 2011 | 09:09 AM
hondakid23's Avatar
but i have oem ballasts right now.. so these ballasts that cost 110$ i can replace with the oem ones i have without modifications?
Old May 8, 2011 | 10:34 AM
01tl4tl's Avatar
please clarify what bulbs you bought and installed?
we require special D2R HID bulbs,,not some 10 buck special you can buy at the parts store
if `normal` bulbs went in and were hit with the super high voltage of the HID starting system--they wont last a second
do you have any moisture issues inside the headlight lens, that can lead to ballast failure
the DIY kits MAY require you cut 2 wires and install 2 connectors,,
the more expensive ones should come with the correct plug and play connector.
They also have waterproof ballast and double stick tape easily mounts anywhere
ck the places listed above- I went to hidextra for a 5000k color full kit, (stock color is 4300) 2 new ballast -bulbs- and ignitor/connector to bulb wire,,
for ~well under~ 75$
price varies with sales and coupons you find online
Old May 8, 2011 | 10:42 AM
01tl4tl's Avatar
there are several of us having this exact problem now-
either water has destroyed inside the ballast or general age and road vibrations are taking their toll
gen2 cars are at an age and headlight use time for new bulbs- may as well do everything and its done..with the low prices of aftermarket it makes sense
thankfully several sponsors that make this site happen-- are hid sellers and experts!
look at each one- not hard to figure out only a few makers of the stuff and several sellers marking things up
bulb quality being the main differance I can find
ck the main page list, and the special section--Problems- for more info and diy tips
the master diy list is here https://acurazine.com/forums/2g-tl-1999-2003-98/new-official-2nd-gen-tl-diy-thread-706083/
save it to your browser favorites- its a lifesaver!
Welcome to acurazine
Old May 8, 2011 | 01:42 PM
hondakid23's Avatar
yes i purchased DR2 bulbs my driver side has some moisture in the headlight so it probably damaged the ballast.. thanks appreciate the prompt responses .. ill check out those websites that you guys gave me
Old May 8, 2011 | 04:30 PM
01tl4tl's Avatar
hidextra will have the lowest prices
good idea to fix that seal leak, but with a new `waterproof` ballast -thats not as big an issue
Old May 9, 2011 | 01:51 PM
hondakid23's Avatar
hidextras are those cheap kits i see them for 59.99$... any good reviews about them?
Old May 9, 2011 | 02:54 PM
03tl-s04mdx's Avatar
I've had the hidextra slim ballast kit on my MDX for almost two months now with no problems. For $60 if the bulbs and ballasts last more than a couple of years I'll be pleased.
Old May 9, 2011 | 03:28 PM
Flipster23's Avatar
HID xtra is decent the have a review section over in the off topic section
Old May 9, 2011 | 04:17 PM
hondakid23's Avatar
does anyone have the 12k that hidextra has... is it deep blue im looking for a deep blue
Old May 9, 2011 | 04:19 PM
Flipster23's Avatar
no 12k is useless u cant see shit
thats ricer status
Old May 9, 2011 | 07:34 PM
hondakid23's Avatar
im lookin on the website theretrofitsource.com and under hid component kit which one am i looking for morimoto amp kit or the d2s kid..sorry such a newbie
Old May 9, 2011 | 09:52 PM
01tl4tl's Avatar
try their customer service !!
Old May 10, 2011 | 10:42 PM
Willie3.5's Avatar
SixSpeedDreamin'
Hondakid23, I responded to your message you sent me, so check it out. If you are not sure give retrofitsource a call and they can definitely help you...As Flipster23 stated stay away from 12K, you literally can't see anything down the road and it strains the eyes more at night. I had 8k and hated it then I went to 6K which was okay, I finally dropped to 5K and love it!
Old May 11, 2011 | 07:28 PM
hondakid23's Avatar
thanks acurazinesfinest i called theretrofitsource customer service an the guy told me all i need to do is when placing the order is make a note in the checkout section to include 9006 appropriate connectors and he told me i dont need a wiring harness he will refund me for that.. any suggestion should i go for it?
Old May 12, 2011 | 10:34 PM
Willie3.5's Avatar
SixSpeedDreamin'
I'd say go for it before you end up with no lights at all, especially at night. That is not a good feeling when both your lights stop working at the same time on a pitch black road. The quality of the morimotos is nice and you won't be disappointed.
CL-S progression 01
Jan 26, 2016 04:15 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
h22lude
Sep 27, 2015 06:22 PM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
Juandiablo
Sep 27, 2015 10:32 AM
