Bad news
It feels and sounds strong, but I cant compare to anything previous as my engine that I replaced with this engine was a D15......in my 94 civic hatchback.... I just got this whole swap up and running a couple days ago... Still working on the hood....
So yeah....hauls ass!!
Chapter Leader (Southeast Region)
Damn I though you had a cl. Looks good and I'm glad you got it running. Will you be able to get your hood on with that manifold or still have to cut a whole
Yeah, cats outta the bag now!! lol
I used to have a 01 cl type-s. I really liked the car, but the dealer spent 6 months trying to get the title for it and never could so I gave him the car back and got a full refund. Love these motors.
I decided that having a hole in the hood was better than having a hole in my oil pan so I went with the mounts that keep stock ground clearance...but I have to modify the hood. I just slapped a junkyard hood on there tonight and rough cut a hole so I could shut it. Now I'm going to make a real nice, close cut template that I can transfer onto my nicely painted hood for a super clean, tight fitting hole.
I came to this site because its the best for these engines. So far it has been quite helpful and I'm glad I can help out some others too on my way..
Update I emailed p2r today and this is the message sent back to me:
The problem your having is the bore on the adapter is bigger than the outer edge of the 01-03 cl-s/tl-s throttle body gasket. A easy fix would be for you to put a touch of Honda bond at the outer edge of the gasket.
So they know it's a problem and keep producing it that way. On top of that there are no instructions included with and certainly nothing mentioning this. This will be the first and last p2r product I buy in my life.
Yeah he should start making them and selling them on the side. It would be more beneficial to all of us and it would help find his projects. Not to mention you couldn't really run anything bigger than a type s throttle body otherwise it would be blocked by the p2r adapter.
I'm stuck out of town till Friday, but I had the acura dealer order me a 09 tb gasket so I could get the hole placement correct. Hopefully by the weekend is over I'll have one made
I may order a blox 75mm tb and make a 2nd one with the holes correct or just a blank where someone could drill their own holes for what ever tb they use
Also forgot anybody that swaps manifold off a tl-p will need new intake manifold bolts. The tl-p and the tl-s have different part numbers or the intake manifold bolts. The type s and the 09 tl share the same part number for the intake manifold bolts
when i get this one fabed up and if it works ill look into making a few, i should have enough material left for 3 or 4 if i dont screw something up once i get the new pipe (ordered 3"id and they sent me 3"od
(i didnt get anywhere on it this weekend, in-laws showed up screwed up my weekend and lack of pipe didnt get me too motivated
but ill have time this week........as long as i can get the 3" id aluminum pipe this week
As soon as i get JCharged's Blox tb im going to see if its possible to integrate both bolt patterns (blox/type-s tb's) so that if when you upgrade its easier
That's an option I've been contemplating. Went out to buy a soldering gun, wires, and shrink tubing today.
Ok, so I have 2 adapters cut out (only one in the pic). Can one of you take a pic of the plate that the throttle body bolts to? I need to make sure that I get the plates welded in the correct orientation
I need to drill holes in the plate I made so that you can bolt it to the intake manifold. I have the gasket to mark the locations, but I need to know which way the gasket goes so that I drill them in the correct spots. I don't need the type s tb, do you have the 09 tb? I need a pic of the intake manifold where the tb bolts to so I can hopefully get the correct orientation
