bad gas milage why??
Old Nov 24, 2008 | 05:25 PM
  #41
rob-2's Avatar
Originally Posted by tlcurt
ok, next tank im trying 93 and will hopefully get better, i dont know for sure what i got on this tank cause i put $10 in saturday night but i was at about 240 miles and over E.
Get ethanol free gas too.
Old Nov 24, 2008 | 06:13 PM
  #42
fsttyms1's Avatar
Originally Posted by rob-2
1gallon 91 @ 30mpg for $2.29 = 7.6c/mile
1gallon 87 @ 30mpg for $2.00 = 6.6c/mile
Your MP$ is less on premium. 10% less. So 30mpg on 91 oc = 33mpg on 87 oc
The difference after 125,000 miles is $1250. Approximately the cost of the 105 service.
Kris' point gets a little fusy when you look at the same cars they produce for Europe.
Euro Accord regular vs. US Acura TSX Premium only
Euro S2000 mid/premium vs. US Honda S2000 premium only
Euro Legend regular vs. US Acura RL premium only
One might debate that the motors are tuned differently for their respective markets and in part this is correct. However their compressions don’t change and that would be the leading factor for predetonation of regular fuel.
Clearly if the s2000 at 11.1 and 9K red line can run midgrade (our 89) then your TL can run regular fuel. Why? Compare the UK Legend with 11.1 3.5v6 to the US RL 11.1 3.5v6. Both the same motors, same power yet only in the US market is it stated to premium.
Then if you really want to start thinking outside the box, start asking yourself why Honda branded cars here have higher compressions and don’t require premium. Then go one step further and ask yourself why Acura is only in the US/Canada. Might it have something to do with brand positioning and our obsession with status?
Just food for thought. Run what you like but dont be affraid to try regular, it wont damage a porsche so it wont damage our fancy accords.
But your whole point is IF you get the same on both. Many dont get the same. You have stated over and over that you do, thats great. You are one of the few. Most dont. I got 26-27 at best on the hwy with it and 31 on average with 91. My city mileage had a much worse drop than my hwy with 87. It would cost me a lot more to run 87 over 91. As it does with many others.
Old Nov 24, 2008 | 06:15 PM
  #43
fsttyms1's Avatar
You cant base results on just one tank either. Also you never answered. You claimed 17 gallons. Did you really run it down to dead empty and put 17 gallons in or just till the low fuel light?
Old Nov 24, 2008 | 08:53 PM
  #44
valeratj's Avatar
Unregistered User
u think u get bad mileage with a 6 cyl sedan? My 2.4L TSX has synthetic oil and K&N filter and does 18-20MPG city. Highway mileage is great tho. I get 34MPG highway and 38 on country roads at 55 mph. No, I am not making the high numbers up. TSX weighs 3300LBS and small engine needs to give an effort into acceleration in the city, but while cruising at 70MPH at 2400RPMS, 2400cc's consume little gas bc they simply have to maintain speed.
Old Nov 24, 2008 | 09:42 PM
  #45
Russell The Love Muscle's Avatar
IIRC "regular" fuel in Europe and Japan is our "premium"
Old Nov 24, 2008 | 11:28 PM
  #46
xdxlx's Avatar
i get horrible gas mileage. ive been averaging like 200-220 per tank, which comes out to be like 14-15 mpg!
but most of my drives are like 5 minutes, and have tons of hills. but i dont ever gun it
Old Nov 25, 2008 | 01:13 PM
  #47
rob-2's Avatar
I believe you'll find the RON system of measure creates higher ratings for gas then ours. So a 93RON is like our 87oc.
Old Nov 25, 2008 | 01:15 PM
  #48
rob-2's Avatar
Since we've moved I've had alot of similar experiences. Taking the wife to and from the train kills my MPG. I got the worst last week (mon-Fri) of 110 miles to 7.2gal or 15.2mpg. Drive thru doesn't help either
Old Nov 25, 2008 | 01:59 PM
  #49
Razzi's Avatar
T-Swzy
maybe it has nothing to do with the motor. could have a slightly seized caliper. could have a bad ball joint. any of the rotating parts in the car could have seized and is resisting motion. if your engine is mechanically fine, take the tires off and look elsewhere
Old Nov 25, 2008 | 07:26 PM
  #50
tlcurt's Avatar
yes, i put 17 gallons in my tank at the pump when i filled it up. xdxlx-im getting about the same as you, hopefully better when i try 93
Old Nov 25, 2008 | 10:25 PM
  #51
Esteban's Avatar
Talk about contrasts... I also have a 99 TL, with 125K miles. On a recent trip from South FL to Orlando, doing only 65 with the cruise control on (yes, I'm a slow driver!), the AC on for about and hour and just me in the car, I got 33 MPG. 460 miles in one tank.
A week before that, I did 10 (yes, ten!) MPG in ONLY city driving, very short trips (no more than 2 miles, going back and forth to work) and lots of cold starts.
Yes, it's true, this car sucks in the city but it's a great highway cruiser. With normal, mixed use, I average anywhere between 17 to 23 MPG.
Also, ever since they started using crappy ethanol in gas, my mileage went down at least 30%, and that is NO exaggeration. I'm sure that had I made that Orlando trip a year ago, with NO ethanol in my gas, I could have gotten at least 35MPG. You are luck if you always average around 300 miles a tank.
Old Nov 26, 2008 | 12:00 AM
  #52
rob-2's Avatar
You were close to running out. I believe the tank is 17.4
Old Nov 26, 2008 | 07:00 AM
  #53
fsttyms1's Avatar
Yea which putting that much in isnt good. You are really running on vapor and crap.
But it comes down to if that is city thats not abnormal and there isnt much to do to help get it better.
xsilverhawkx
Oct 5, 2015 11:00 AM
Skirmich
Oct 1, 2015 12:59 PM
San Yasin
Sep 29, 2015 10:52 AM
hrothgar02
Sep 28, 2015 11:08 AM
