Axle removal process
B93P TL Owner
What is the difficulty level (1=easiest, 5=hardest) in changing out a halfshaft (axle)? I've tried to do a search, but couldn't find any instructions on removing one. Thanks!
on a 1-5 scale 3
drivers side: remove the half shaft nut (the hardest part) then remove teh lower ball joint using a seperator fork. remove from spindle. then get something behind (againts tranny) and pop it out of the tranny (dont pull to hard or you will seperate them internally)
passenger side simillar to driverside but the passenger side has a intermediate shaft and bearing attached to it to make it a equil length half shaft
![](http://img14.echo.cx/img14/9416/picture1008eu.jpg)
B93P TL Owner
Thanks Kris. Your instuctions are very straight forward! I guess looking at your picture it is safe to assume that you've had the passenger side replaced. Did you use a torque wrench to loosen the axle nut? What size socket is rq'd?
i had to take mine out when i changed my tranny. there is a little figiting to do to get them out but they will come out. as for the socket, its a 36mm. i used a breaker bar and a 3 foot pipe. 1 of mine came off relativly easy the other needed the pipe. but they will come off
dainmezron
10-16-2015 06:56 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
