Axle Change now vibration
Styl1n
Hey guys wats up....do i need to get realigned after my axle change? i got them changed and i noticed that we had to loose the bottom braket that holds the strut. now no notice there is a vibration while driving over 60 feels like wheels are not balanced
thanks
thanks
you should not need an alignment after an axle change.
somthing is wrong, what bracket did you not re use?
post a pic.
who did the work?
is everything tight, and installed properly?
was the dampener on the axle still intact when you installed it?
was it a brand new axle or a used one?
we need more info.
post a pic.
who did the work?
we need more info.
Styl1n
axle was brand new and everything was tight but i am going to get my neighbor to double check all the bolts again to make sure everything is tight and secure
any ideas on what to double check...everything was new
first thing, check the wheel to see if the weight is still on there.
always look for the easiest/stupidest thing first.
who did the work? take it back to them and tell them to make it right.
dont have anyone who wasnt involved in the work look at it, or touch it. it could ruin all your chances of getting it fixed for free by the guy who did the work.
he could say "someone else was messing around in here, its not my problem" or something like that
Could be a bad axle that you put in. Another member just had axles replaced and had vibrations right after about that speed. Put in new axles and it went away. I agree though to go over all bolts and make sure every thing is tight first.
Styl1n
got them from worldpac they supply a lot of parts and good stuff, all my tie rods and ball joints came from them
its weird they problem i had before was at 40 moh now its over 60 mph i feel this well actually from 50 up
the ride feel choppy
Styl1n
hey guys do you think its a mount that can be bad? maye the tranny mount because i do notice only above 50 this vibration happens and if i am in fifth and give it some gas i get a hard downshift like the tranny jumps into 4th....thanks
The hard downshift from 5th to 4th could possibly be bad engine mounts. If you are getting a vibration after the axle change then it could be possible that the axles are binding up since your car is lowered.
Styl1n
heres an update guys...looks like its my tires....they are cambered out and makes alot or road noise....and really choppy...axles are good i need to get the camber kits and new tires soon...
