AV6 tranny - changing poly motor mounts back to oem due to annoying idle vibration
Since I didn't install the av6, (bought it like that) I'm not sure if I should use the stock tranny mount for the 03 tls (my car) or 06-07 accord mount, eh?
Also would I need one or two? After much research, I've concluded nothing beats the oem mounts if you want no vibration at idle. I also have a ingalls damper which will hopefully reduce wear on the new mounts. These suckers are expensive to replace oem, I hope it's worth it!
You use the stock mounts for the TL-S with the AV6 transmission and there are two of them to replace.
There's definitely no doubt that the OEM mounts are the best choice if you want to feel the least amount of vibration, but the slight trade off is that they need to be replaced a little more often.
