AV6 Swap Question
Old Oct 8, 2017 | 11:07 AM
michaeldove's Avatar
AV6 Swap Question
A couple newbe questions...
Does anyone know the torque converter mainshaft oring size?
Does anyone know the AFT warmer orings size?
Before I install the AV6 into my TL do I need to fill the torque converter with fluid?
Old Oct 17, 2017 | 02:08 PM
marso's Avatar
You can get the orings from an online Acura dealer. Look for one and go through part breakdown lists to find them. I always fill the torque converter prior to installation.
Old Oct 17, 2017 | 05:16 PM
SuperGreg's Avatar
O-ring part numbers listed here for ATF warmer: https://havenergarage.blogspot.com/2...ra-tl-av6.html
- Passage body gasket (25812-P7W-A01)
- Passage body o-ring (91302-P7W-A00)
- ATF warmer o-rings x 2 (19435-P8E-A01)
I'm not sure about the TC seal.
Old Oct 17, 2017 | 06:49 PM
Skirmich's Avatar
Buy the TC seal from an Accord V6 Catalog.
I did not replace the ATF Warmer O-Rings, They do not leak.
Yes, You can fill the TC with ATF but do not top it off as it will create a mess when you are trying to fit on to the transmission.
Gregbrown
Oct 8, 2017 06:34 PM
