AV6 sensor questions
Old Nov 4, 2017 | 09:27 PM
marso's Avatar
I bought a rebuilt AV6 but it didn't come with any sensors or solenoids. Can I swap all of them from the TLS tranny or do I need to buy all new Honda parts?
Old Nov 5, 2017 | 01:57 AM
Skirmich's Avatar
They all look the same to the eye but can´t say about the internal specifications. I would get new ones but will come out quite expensive.
Old Nov 5, 2017 | 02:50 AM
Iggy's Avatar
Take a look at local junkyards, you might get lucky and find some off an AV6
Old Nov 5, 2017 | 12:23 PM
01acls's Avatar
Yes they are the same unless it's obvious that the parts don't match up.
Old Nov 5, 2017 | 01:52 PM
marso's Avatar
I compared part numbers between the BAYA and TL trans and it seems they are the same except the 3rd and 4th pressure sensors but the Honda site may have the old part numbers. Might have to cross reference.
Old Nov 5, 2017 | 03:09 PM
01acls's Avatar
Pretty sure they are the same because they're color coded and if it plugs in to the harness then it's made for that Switch. Also peeps have use Honda Switches with the TL ecm, if they were not the same the third n fourth gears would exhibit incompatibility issues.
