Auto leveling HIDs
Auto leveling HIDs
In Europe, cars equipped with HIDs are requlred to have auto-leveling, and other manufacturers like Lexus has them too. What exactly does auto-leveling do? If you are going up a hill, will the lights aim lower? Or does it auto-level just during acceleration or when the rear of the car is loaded down? Either way, I think it is a safety feature that Acura should consider having since you basically blind oncoming drivers when you accelerate or go over a bump.
Lexus has auto leveling HIDs? I thought only the German trio had those. :confsued: Anyways, since there are so many critics of HID lighting, I predict that the DOT will mandate auto leveling HIDs just like Europe to get all the complainers off their backs.
![Lightbulb](https://acurazine.com/forums/images/icons/icon3.gif)
Yup all Lexus models have auto-level HID's. It really only adjusts to when you have 5 people in your car or tons of stuff in the trunk. Instead of the headlights aiming in the sky, they adjust on the road.
On the GS, when you turn on the lights, you can see part of theheadlight move in then out, pretty cool.....
¤ Club Inspire ¤
Yeah, I've seen those in action on my friend's Benz S500...I really want those....i didn't know Lexus has those too!!
Acura should do these.then I'll complain and make them install it... :p :p
![Mad](https://acurazine.com/forums/images/smilies/mad.gif)
So, is the auto-leveling just based on the load of the rear end of the car, or based on the tilt of the car? For example, if you are going up a steep hill, will the auto-leveling point the lights down, thus not lighting the road ahead?
It usually depends on how compressed the front springs are. If you load up on the back of the car, the front will tend to lift, and the headlights will lower to compensate. If you brake suddenly, the nose will dive, and the headlights will rise.
I don't know if the Lexus, BMW or MB systems do it that way, but if they do, it'd be pretty challenging to lower the car without causing the headlight to point skyward all the time.
The HID's will not move because the car is still level with the ground. But say Polyman's 800lbs mother sits on the hood while you are going uphill. Then the hood will be lower and the HID's will self adjust.
The point is not to blind oncoming traffic (like those @#%^ SUV's with HID's)........
Or read daverman's post
MB-Fanatic w/TL-S
1 Post
Funny isn't it, it seems Auto-Leveling is a great feature for HID equipped cars, yet Honda/Nissan doesn't use it.... and yes ALL Lexus model with HID has auto-leveling....
As Daverman and 1SickLex explained, Auto-Leveling keeps the light beam properly aim toward the front of the car and automatcially compensate for any loads added to the car...
However, from what I know(and on MBs anyways), the auto-leveling sensor is mounted on REAR suspension??
Andy Kuo
Andy Kuo
¤ Club Inspire ¤
IF it's mounted on the suspension....and when you use lowering springs...which brings the body of the car down as you would put a heavy load into the trunk....So shouldn't it shoot the beam very low? or high? or would it still function properly?
i didn't know the HIDs were sensored by the suspension, i thot they use a gyroscope like device, like in the airplanes to see if the car was tilted forward or back...and it would adjust accordingly? that's what i figured they would do rather than stick it on the suspension.
¤ Club Inspire ¤
I wouldn't think the auto-leveling would be based on a gyro, otherwise, when you go up a steep hill, the lights will point down at the ground, and when going down, they would point up. But I'm just guessing on this.
up hill, lights point down
down hill, lights point up...
shouldn't a gryo do the opposite? when the car is pointing up, the lights point down, and when the car is pointing down, the lights point up....
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
The auto-leveling system keeps the HID's level relative to a line drawn from the bottom of the front tire to the bottom of the rear tire.
www.cardomain.com/id/perr
Andy Kuo
Andy Kuo
waste of momey? hehee, it adds to the price of the car of course...that's why it's so freakin expensive!
not a total waste...but it' does add safety to other drivers...so we wont blind them with our cool lights
MB-Fanatic w/TL-S
1 Post
Originally posted by perrymaxima
AKRY not to nick-pick, but Infiniti uses auto leveling on the Q45.
Andy Kuo
:o :o :o Isn't Q45 came with a knob on dash that let you adjust headlight aims up/down remotely??? It says nothing about auto-leveling in Q45 brochures though..... :p
Andy Kuo
Andy Kuo
Originally posted by Closer
Am I the only one that thinks this is just a giant waste of money?
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
Originally posted by asiankidd
you cant just complain and have them install it?!?! reason why i think the tl doesnt have it is cus its made in the us and only imported car's that go thru custom are required to have them....i know on the mercedes 2 things are required to make xenon hid LEGAL 1 is the auto leveling and 2 is the Head lamp washer....its cant be purchased with out 1 or the other....
MB-Fanatic w/TL-S
1 Post
Originally posted by TedC
I'm pretty sure that it was more of a cost-cutting issue than anything else, as all of these cars mentioned with auto-leveling cost more $$$$ than the TLS.
Andy Kuo
MB-Fanatic w/TL-S
1 Post
Maybe your right there a new Q45 site and on there he has a video of his HID's leveling them selves maybe there's a knob.:o
Andy Kuo
Guest
Posts: n/a
In Europe self leveling headlamps have been around for a long time as I remember back in the early 80's seing gray market Benzes with this equipment,this was long before H.I.D. lighting became available.One thing all of you need to remember is that lighting laws in the U.S. are at best archaic .This is one reason why gadgets like H.I.D. self leveling headlights etc are so slow to be marketed here.Self leveling headlamps are always linked to the suspension system not to a gyroscope .The idea is to level the lights relative to the car not the road.Acura/Honda designed the TL some time ago prior to it being legal to have self leveling lighting so this may be part of the reason why the TL was not designed with this feature.Possibly with the next gen TL/CL Acura may elect to employ this system.Also remember this stuff is expensive so rather than hear people gripe about the high cost of cars and lose people to other cheaper brands they leave some features out.Now granted some of you are probably saying but XXXXX brand car maker has this gadget but their car is almost the same price as ours WTF???? Well just remember if you go to the forums for XXXXX brand car you will hear those owners of XXXXX brand car say the same thing about our cars.SO give it a bit of time and these gadgets will also appear in our cars when the cost is more reasonable because the cost can be spread across more cars using essentially the same equipment.
AcuraAddict cool can't wait to see how this works out for you .Jens
spoiler900
10-10-2015 06:48 PM
