ATTN: Wayne or Jens
5th Gear
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
Recently I've had my right HID bulb replaced(victim of theft). What puzzles me is that the replacement bulb, which is a genuine Acura part and was ordered and installed by the body shop, appears to be more "yellowish" than the one from the factory. This begs the question: Does Acura use a different supplier for the replacement bulbs? As far as I know, the "factory bulbs" are manufactured by Philips; I know that for a fact because the body shop owner showed me the broken bulb that the thieve hadn't succeded in taking. Any feedback and comments will be greatly appreciated!
Guest
Posts: n/a
For whatever mysterious reason this has happened to us as well on a few occasions with brand new parts out of the box.It appears that most of the bulbs in the parts loop are white in appearance and a few that are more yellow in appearance.The only thing we were able to do was to try out a few bulbs that matched.This problem first reared it's head early on when headlight theft first started but then we did not see it again.It may be that the source for your bulb may have had a very early production bulb .I seem to remember our parts people making a number of calls about this to the powers that be at Acura but nothing ever came of it.I would suggest you visit your dealer and explain the situation if you have receipts for the parts it should be alright for them to exchange under warranty the bulb .We have had to do this a few times in the past but remember you will need to show receipts since the part was installed by your body shop.Jens
5th Gear
But Jens, do you know who the supplier of the replacement bulbs is? If it is anything other than Philips then I can see why they would look different from the factory bulbs. In that case, I guess I'm out of luck and see myself having to purchase another replacement bulb to match the one that's already on.
Guest
Posts: n/a
I will have to look and see who makes the bulbs for us .My guess as to the color difference is that maybe Acura changed suppliers or a production change caused this to happen.As far as I know and what threw us for a loop was that even though a few bulbs came through the parts pipe line with a different color the part number never changed.Jens
Super Troll
Originally posted by TommiGSR
instead of replacing the factory bulbs, should've gotten the 6000k bulbs instead from autolampsonline.com, you won't be disappointed.
5th Gear
Thanks a million, Jens; you've been a great help! Okay, I now have the official confirmation that Acura DOES use a different supplier for their CL/TL's replacement light bulbs-mystery solved and this is the good news. The bad news is, I now have to get another replacement bulb to match the one that's on the car. Jens, is there any way I could order the part through your dealership by phone or online and make an appointment to have it installed at a later date?
