Attn: Street Effectz
Guest
Posts: n/a
Thanks alot for the info.
Here is the situation with the window roll up. If you hold the lock turned to the lock position after it locks, it will roll up any open windows and close the sunroof.
Im assuming that accessing this via remote would just be applying (-) 12V to the lock wire for a longer period of time. Am I on the right track?
Also, I would need to isolate the inputs to the lock wire from the two different channels with diodes. Now just as a refresher since it has been a lil while, which side does the stripe go on? the source side, or the output side.
Now, are there relays or modules that would apply a current for a specific period of time, ie the time required to close the windows / roof, hopefully it will be adjustable to different time increments, as I dont know exactly how long it would take yet. I can time it if that's an issue though.
Thanks for all the help,
George Androulakis
George Androulakis
DerrickW
11-15-2015 05:52 PM
