Attn: '99 TLs with AEM CAI.........
Old 06-24-2001 | 07:22 PM
BlackShadow's Avatar
O.G.
Question Attn: '99 TLs with AEM CAI.........
I just ordered the AEM CAI from Tim (my very first order). My question to you guys is:
1. There is a piece (I am guessing the alarm horn) that is in the way of installing the AEM CAI, where do I remove it to?
2. Anything else I need to know before installing the AEM CAI?
3. How long does it take for it to get to NJ?
4. Do I need to buy the air bypass valve if I live in NJ?
It's not like I am installing it myself anyways. My boy j83 is going to install it for me.
Thanks!
Binh
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by BlackShadow on June 24, 2001 @ ]</font>
Old 06-24-2001 | 10:05 PM
adamyankee's Avatar
Post
The alarm horn can be mounted to the rubber piece that AEM gives you to go into that hole.
Just put the hole of the alram horn bracket under the arm of the upper pipe and turn it towards the left side of the car.
Next, your stock filter box has a mini-radiator designed to heat up the air quicker.It will have a hose coming from the engine into it and then back out to the engine. You will need to get a small piece of 5/16 inch pipe about 1 inch long to bypass the filter box.
Be careful, because once you remove the hoses, antifreeze will pour out and that shit could be HOT!! Put a cup underneath to catch it. Don't worry, it won't fill up too much . About 4-6 ozs. Put the piece of tube in each end of the hoses using the stock clamps and use join the two ends together. Bypass done.
Next, the lower pipe will connect to a hole being used by a wire loom behind the headlight. Remove teh loom and use that hole.
Check my pics. When are you doing it? Maybe I'll take a ride and help.
http://www.acura-tl.com/ubb/Forum1/HTML/008778.html
Under Body Kit/Rear Wing Spoiler/02 Tails/30% Smoke Tint/Comptech Sways & Springs/Altstadt I's with 225/45-17/Clear AEM CAI/BurlWood Shift Knob/26 Piece Wood Grain Console
More Pics
Moderator Acura-TL.com Tires/Wheels Forum
Old 06-24-2001 | 11:11 PM
O.G.
Post
Thanks Adam.
BTW, I'm not too familiar with the AEM CAI, but did you get the bypass valve? Do I really need one?
Old 06-25-2001 | 12:38 AM
Acura3200's Avatar
Post
just get the bypass valve
what's $30 compared to a new engine (not replaced under warranty)
it's also a good piece of mind... don't have to worry about it if it starts to rain hard... TRUST ME... it will make you feel better. I drove back from Limerock yesterday under hurricane like rain and huge puddles and I was worried, but felt better knowing I have the bypass installed.
<A HREF="http://www.adamoski.com/acura.html" TARGET=_blank> </A>
Old 06-25-2001 | 01:02 AM
SLVR TL's Avatar
Post
It might be a good idea to get the valve since the filter is so close to the bottom of the car. And it's not that expensive either.
Y2K SiLVeR TL, non-navi
SLVR TL Homepage Last updated 6/9/01
Old 06-25-2001 | 10:36 AM
O.G.
Post
Can I buy the bypass valve at any automotive store?
Old 06-25-2001 | 10:45 AM
99WDP's Avatar
Post
Any place that sells AEM products should have the bypass valve.
Old 06-25-2001 | 04:27 PM
adamyankee's Avatar
Exclamation
Be sure to buy part #20-402. It is the bypass valve with the 2.75 inch diameter.
07-16-2017 08:33 AM
jmaxima03
09-27-2015 11:22 AM
kingbharj
09-25-2015 08:25 PM
Quick Reply: Attn: '99 TLs with AEM CAI.........
