ATF drain plug washer
Old 09-13-2002 | 11:36 AM
KJ32's Avatar
Anyone who did their own ATF changed, is the size of the washers for the drain plug bigger than the washer for oil pan drain plug? Also, is there a washer for the filler plug for ATF? Thanks a bunch.
Old 09-13-2002 | 11:42 AM
randomwalk101's Avatar
You can buy new washers from the dealer. It is of a "crush" kind to seal...but I just reuse mind...even with the oil drain one..and it'll work. No leak.
Old 09-13-2002 | 01:39 PM
KJ32's Avatar
I bought them already and had one of them installed because the mechanic said there's only one and he used the 18mm (bigger) one. I am wondering if he's telling me the truth.
Old 09-13-2002 | 03:43 PM
mr tl's Avatar
theres also one for the filler hole but its not really needed.
Old 09-13-2002 | 11:05 PM
KJ32's Avatar
I still want to verify the 18mm (bigger one) is for drain plyg, anyone plz?
Old 09-13-2002 | 11:07 PM
Simplist way is when you change your oil, take the old one off and compare...cuz nobody here knows...and who really pay attention to details such as that to answer your question. Certainly, nobody will run out there pull it out just to check...got the drift?
Old 09-13-2002 | 11:13 PM
KJ32's Avatar
I believe there are lots of DIYer who noticed that. if you don't know, that's cool.
Mike734
12-10-2021 01:25 PM
ITSJESTER
17
12-06-2018 02:29 AM
MetalGearTypeS
08-29-2016 08:28 PM
Joe Avesyan
09-29-2015 03:57 PM
hashbrown
09-29-2015 12:13 PM
Quick Reply: ATF drain plug washer
