Apexi RSM setting for TL
I just installed my RSM today and got it properly setup. Here are the settings to make it work properly
Cylinder: 2
Sp1: 4P
Adj: 100%
I'm not sure why cyl=6 would not work. If you use 6, the RPM reading will be all wrong. If you use 2, the idle the reading is still off. But as soon as the car starts rolling, the RPM is right again. I was told this has to do with the firing sequence of tthe cylinders.
Now I can do 1/4 mile, 0-60/100 anytime anywhere I want It sure is fun to play with it, especially at night
Cylinder: 2
Sp1: 4P
Adj: 100%
Biggie_B
02-26-2017 11:14 AM
