Anyone know how to remove the outer door handle?
Old Oct 28, 2009 | 03:34 PM
AcuraTL99's Avatar
As the title states.
The spring broke off cause I heard a snap when I opened the door.
Old Oct 28, 2009 | 04:39 PM
friesm2000's Avatar
B A N N E D
pull off the interior door panel and get to the outer door handle from inside the door,
door handle will two rod with clips one for the lock, and one for the handle] then there will be a 10mm nut/bolt holding it on
just be happy it's not a ford exploder where you have to drill out rivets for the handle to come off
Old Oct 28, 2009 | 04:41 PM
AcuraTL99's Avatar
Okay, I'm at the part with the rods.
I'm still confused, I already took of the 10mm bolts on the door handle.
How do those come off?
Old Oct 28, 2009 | 05:25 PM
fsttyms1's Avatar
how does what come off the rods? The plastic clip has to swivel off to one side, then the rod can lift up and out.
Old Oct 28, 2009 | 06:59 PM
AcuraTL99's Avatar
If you look from the inside, there is a rod that is connected to the outer handle.
That's where I'm stuck; don't know how to remove that.
Old Oct 28, 2009 | 07:22 PM
friesm2000's Avatar
B A N N E D
there should be a plastic clip, if not, then you have to disconnect it from the latch/lock itself
Old Oct 28, 2009 | 08:35 PM
MegaKillTron's Avatar
The wood god
Oh man, good luck. I had to replace the rear door handle too. I still haven't put the lock back in place, haha.
Old Oct 29, 2009 | 05:13 PM
AcuraTL99's Avatar
Is it the rod that's holding the spring or the handle?
Can I just go to a hardware store to buy a spring?
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
tman570
Jun 11, 2019 07:56 AM
Sep 17, 2015 10:16 AM
CadiGTi
Sep 14, 2015 06:37 PM
