anyone have the progress anti roll bar installed how is it?
hey do any of you guys have the progress anti roll bar installed if so how is it? is it a big difference can you see it from the rear of the car?
if you dont know what i am talking about here you go http://www.jdmhub.com/index.php?rout...duct_id=217501
Get a complete kit, (front and rear) you will see a even larger difference.
there is only front frame crossbars available for the TL- upper and lower and they really help in turns--
reason- not a made in jdm car like tsx, which you can buy about 20 stiffening bar segments and turn it into a full racer
the sway bar size can be increased a few mm if you want,, with progress brand or other.
Make sure to replace the crappy stock end link/connectors with MOOG brand,
much better and easier to install
optional- install polyurethane bushings and new end links on stock sway bars for an improvement without giving up all the smooth of the TL
Short answer:
Installed it last Spring. Noticed a difference right away. Rear end felt more planted.
Long answer:
Stock vs. Progress
Replaced my front lower strut bar at the same time. Ripped my old one off on a man hole cover
For reference, the upper strut bar from Cusco
The RSB, lower, & upper strut bars are a "relatively" inexpensive combo of mods where you'll actually notice a performance difference after installing. If you're really concerned about sucking some extra handling from this glorified Honda Accord, I'd look at GOOD tires and a lighter wheel. I realize that's a more expensive investment, but if it's doable, it's also very noticeable.
I carefully chose 17x8 enkei rpf1's.. w/ a quality meaty tire... to absorb the road and add some "bite". They're an 1" taller & 1.5" wider than stock wheels. Yet each wheel/tire combo is 10lbs lighter. 10lbs less rotational mass on each corner of the car. Some people go for the 19's w/ stretched tire -- that's not me... To each their own.
"Be mindful of what comes between you and the earth. Buy good tires, good sheets, and good shoes"
Long answer:
Stock vs. Progress
