Anyone have hesitation while accelerating from stop light
Old Jun 23, 2005 | 02:16 AM
I have a 1999 TL with roughly 123k miles. My engine has a slight hesitation when I accelerate from a complete stop. It takes a second or two before the car moves after I apply the gas. It kinda dangerous when I'm trying to get into traffic when my car hesitates like this. Do any of you guys have this same problem? Any ideas on whats causing this?
Old Jun 23, 2005 | 02:21 AM
TeknoKing's Avatar
one thread is not enough?
Old Jun 23, 2005 | 02:28 AM
pimpravi's Avatar
I pimp an Audi A4.
happened to me....... got my tanny replaced......... its doing it again... i hope i dont have to get my tranny replaced.......
Old Jun 23, 2005 | 06:59 AM
ojen924's Avatar
did u check your filters (air and fuel), check your spark plugs maybe its time for a change and also did u do your 120k major service?
Old Jun 23, 2005 | 08:29 AM
sbuswell's Avatar
I need 2 more gears
spark plugs, air filter, clean your Throttlebody, get an oil change(mobil1, purolator filter), after oil change get a bottle of Gumout complete fuel system cleaner and when you are near empty pour that stuff in and fill up with 93. I doubt its your tranny. Most likely your IM and EGR ports are clogged and TB is probably sticking a little bit. TB cleaner will help a lot, but to fix problem you would need to take off IM and TB and clean them completely. What you are experiencing is common for high mileage cars, just needs some general mantenance to fix.
Old Jun 23, 2005 | 11:06 AM
MegaKillTron's Avatar
The wood god
samething with mine and sometimes when im driving between 40-60 i floor it and nothing happens till 2seconds later i only have 62000 on 2000 TL-p
Old Jun 23, 2005 | 11:23 AM
TL_S_Driver's Avatar
i thnk ure hesitation is a result of the tranny downshifting to accomodate the request for extra power. u do have an automatic tranny correct?
Old Jun 23, 2005 | 11:28 AM
NSXNEXT's Avatar
Too much play in the throttle cable?
Do the rpms go up before you start moving?
Torque converter going?
Could be a lot of things.
Check the tension on the throttle cable first. Cheap fix.
Old Jun 23, 2005 | 11:44 AM
fsttyms1's Avatar
agree. check the little things first. when was the last time the plugs were changed?
Old Jun 23, 2005 | 06:27 PM
PhxAcura's Avatar
plugs could be the prob...
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
PortlandRL
Sep 14, 2015 12:01 PM
