Any Relationship in these Electrical Failures
Old Jun 20, 2005 | 12:20 PM
Professor's Avatar
Карты убийцы
A few weeks ago, I rock broke the left fog light on my 2003 TL. Soon thereafter, we noticed the backlight on the clock failed, the power outlet below wouldn't work, and the backlights on the transmission shifter went out.
I checked the fuse for the clock, but didn't see any for the other problems. I forgot to pull the one for the foglights.
Could the broken foglight be the cause or could it be condensation from the A/C dripping behind the dash and shorting things out?
Old Jun 20, 2005 | 12:27 PM
TeknoKing's Avatar
hmm, AC wont do it..did u check all the fuses? like the one under the hood?
since so many things are out it has to be a fuse, unless you've been splicing and dicing wires on your own.
g00d luck.
Old Jun 20, 2005 | 12:33 PM
Bxscig's Avatar
There is also a instrumental panel lights and I think the ACC is for the power outlet. I dont see any reason that the fog light would affect all the other items and if it does, i would totally be surprised. The wiring is seperate when I last checked the fog lights. Even if the bulb burned out there is no reason why it would affect all the internal stuff.
Old Jun 20, 2005 | 12:41 PM
Pure Adrenaline's Avatar
Dragging knees in
Sometimes a single fuse could control the damnedest odd combination of electrical parts on the car. For example, my friend blew a fuse on his Integra and the clock display, dome light, and the radio went out.
Did you check ALL fuses? There's a fusebox on the driver's side, on the passenger's side, and in the engine bay.
Old Jun 20, 2005 | 01:42 PM
Bxscig's Avatar
Agreed but I dont think it crosses at in this case. From memory of the diagram I am pretty sure they are independent for the most part. The backlight and the radio I believe are part of the ACC as well.
Old Jun 20, 2005 | 03:34 PM
Tyzing's Avatar
question about fuses on my moms car she has a 2000 Quest....her radio would always have sound but the clock and screen would go out....thats a bad connection right not a fuse?
Jamus22
Jun 11, 2023 10:08 AM
MrHeeltoe
20
Feb 23, 2023 01:54 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
