annoying buzz sound
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
Just wondering if anybody else has the same problem: I always hear this annoying "buzz" sound coming from the engine everytime I start my car and shift it in drive while the car is in it's first initial movement. I brought that up to the dealer and he claims that it's just the anti-lock brakes building up pressure. I have a friend with a TL-P and he never hears this noise. Could it be because our TL-S has 4 channel anti-lock breaks as opposed to the TL-P's 2? It only happens after I shut the car off and restart it at a later time. Should I be concerned? Btw, it used to only buzz once, but recently, it's starting to buzz twice.
axleback
axleback
Re: annoying buzz sound
axleback
axleback
okie dokie. I guess I'm just being picky then. Even my brother's 2001 Civic doesn't make that noise. So, does that mean my friend's TL-P anti-lock brakes aren't functioning properly since his doesn't make the buzz sound?
axleback
axleback
check your manual
I will have to check to be sure, but I am pretty sure it says in the manual that the ABS checks itself once at like 5mph and again at like 20mph. You may not notice the second buzz if you already have cranked up the stereo or are speeding out of your space, like i do.
The TL-S should buzz twice, and all the time. You may not always hear it because of other noises (loud radio, windows down, etc), but it does do it.
The first buzz you hear is when you first put the car in motion in either direction, usually under 5 mph and almost right away. This is your ABS self-test as the dealer stated. Completely normal and all cars with ABS do it--just some are louder than others.
The second buzz you hear is when you are in drive and reach approx 15 mph (or thereabouts). Usually it will happen within the first few seconds of driving. Engine RPMs and tire noise can also drown out this buzz but it is there. This is also the ABS doing a self-test but this time it is because the VSA is doing a self-test. Because VSA uses the ABS system to control wheelspin and correct oversteer/understeer, part of its self-test is to test the ABS sytem independant of the original test. Hence, two ABS tests. Again, completely normal.
I don't know if the TCS system does the same kind of test but I imagine it would since TCS also uses ABS to get its job done. Therefore, the TL-Ps may only have the one buzz (test).
ABS Accumulator buzz
I was also told by the dealer it was normal in my '96 3.2TL. But if it's annoying enough for people to have to inquire, it shouldn't be called 'normal'. It's so noticeable, people are always asking me, "What's that sound?" when they're in my car. I'm sick of explaining.
Seems like from the posts of current model TL and CL owners, they haven't corrected the buzz. Regarding it being normal on ABS cars, it's not! People don't ask about buzzing noises in my wife's LexGS. ABS systems may do 'self-checks' but they do it discreetly, they don't announce it to everyone within ear-shot. I sure don't care to know when my car's checking itself. Does the ECU announce "SELF CHECK!" every time it checks the fuel mixture?
I don't know if anyone else notices this. But my car buzzes when the engine is OFF
. Whenever I wash my car, and sometimes when I'm just in the garage, I can hear my car buzz. The buzz happens once every 20 - 30 minutes or so. It's just a low-frequency buzz. Anyone else notice this?
![EEK!](https://acurazine.com/forums/images/smilies/eek.gif)
Re: ABS Accumulator buzz
mlody
12-04-2019 02:11 PM
DerrickW
11-15-2015 05:52 PM
