Amsoil....
It, and a few others, are the best oil money can buy for a car. Is the sliperiest, protects the best, flows well cold, doesn't burn off or change when hot, lasts the longest and so on. A car using a good synthetic will show the same amount of wear theoretically at 200K miles as the same car using dyno oil at 100K BUT....there are a million opinions on this and the facts could be argued for days! But what I have said is my general belief. I will also venture to say that IMO Amsoil, changed with a good filter every 6000 miles will result in an otherwise taken care of engine a 250 to 300K mile useful life, or more. Again, just my 2CW.
I use it, and since I buy direct from Amsoil's East Coast Distribution it works out cheaper than regular oil at the dealer since I change every 12,000kms
Noticed the engine revs very very freely and has more of that great high pitched windup.
TLS RULZ
TLS RULZ
TLS RULZ
TLS RULZ
Thanks,
Amsoil is good oil. Not that much better than Mobil1 tho'. when you start to factor in cost - amsoil gets quite expensive.
As for extendted oil drains...go for it - but please use oil analysis @ 5k or so to make sure the oil is holding up.
Oil tends to act very different in different engines.
I use M1 SS 5W-30 with oversized filter. I change every 7500.
M1 is $18 for a 5QT jug at Wally -world. that sure beats Amsoil.
I used Amsoil for my 1st oil change. $100 for case of oil & 2 filters.
I noticed no difference in performance or MPG vs. the M1.
Oil analysis was virtually identical @ 6k miles of use.
Randy B
Friendswood TX '03 WDP TL-S
Randy B
