Amazing Change!
TL Q(
Amazing Change!
i'v been hatin my 01 TL's fuel economy problem. Averaging about 250 - 260 a tank in Los Angeles. Just 3 days ago, i decided to give it a oil change w/ Mobile1 n Mobile 1 oil filter; Chevron Fuel Injector Cleaner; and balanced my air pressure to 36 PSI. I went from L.A. to Las Vegas with only 3/5 tank of gas w/ AC fully functioning. That tank of gas gave me 300 miles on LA to Vegas freeway miles AND 80 more on vegas Local. HAPPY HAPPY!! And on my way back, filled it up at "mobil" and gave me 400 miles freeway and LED still haven't come on yet! HaPPY haPPY happY!
By the way, i also went to Vegas 2 months ago w/ my old oil, i barely made it w/ a tank! u ROCK "MOBILE1"
Crap - I've been wondering about this.
I only get about 300 max on my '02 Type-S.
I did a complete 35,000 mile overhaul at the dealer (a thousand bucks!?!?!), and I still get the same results. So what do I do to fix this? Is it really that much of a difference with the Mobil filter?
05 C230K & 09 135i 6MT
I bet your dealer loves you.
Sippy Cup (x2)
Wow, I am suprised to hear that just using different oil and and filter would increase your gas mileage so much. I have always used K&N oil fliters but if this can actually increase mileage that much then I think I will give it a shot the next time I change my oil.
I love cars!
Originally Posted by 03CoupeV6
Holy waste of money, batman. No car needs $1000 worth of work at 35,000 miles. You don't need that much work at 135,000 on most cars.
I'm at 285 with 1/4 tank left. This is not a good tank for my car. Last tank was 357, 87 octane. This tank is 93 octane. I'm starting to feel like I get better mileage with 87.
are you sure you're doing the same driving route/style? i did a trrip to six flags and i got just about 220 mi for the first half - that's all highway.. filled it up , then i did some city/highway and got only 130 mi for the first half.... bigg difference..
Yeah, I am driving the same. I always do. I drive from my Atlanta Suburb to Atlanta once a week, and around in town the rest. I've gotten 403 miles doing that out of 87 octane.
Perhaps it isn't so bad? It was at 1/2 tank at 200 for this tank, and is at 1/4 tank at (now) 300 miles. I was driving earlier and realized this tank's probably going to yield 400 or close, because I do 50 miles past the gas light every time (and it will never hold more than 15 gallons).
The New 3 Series Coupe
actually, I'm not too certain that motor oil will increase your milage, but I now know that on NON stop freeways, our TLPs can go all the way up to 425 miles.
I took a trip last summer and for one tank i experaminted by driving 70-75 mph, for one tank. I averaged just over 29 mpg!! I was impressed. I recently cleaned the Throttle Body and intake manifold. That made it even better. There is a great DIY here on the cleaning.
Can someone tell me where this is...for some reason my internet wont load the search page today
Fresh oil can affect your gas mileage. The new filter has probably less to do with the increase in your gas mileage. If you think of your oil viscosity new and after several thousand miles. There is a decent difference. The old oil flows less efficiently and creates more friction than new oil. I notice a difference in performance around 6000miles on Mobil1 but I don't change it till 7500.
ARRGHHHH!!!!!
i changed my oil to synthetic, new airfilter, put pressure in the tires, and im still getting SHITTY MILEAGE!!!
i got 303 to the gas light today, half freeway half city, thats only like 20mpg, ill get 200 to the tank if all city, abuot 350 to the tank all highway, its a huge difference
FUUUCK!!! someone post up that throttle body DIY, ive been itching to do some work on my car and get my hands dirty
How many RPM's does your tranny shift at? If it is shifting at 3200-3800RPM you have a moderately heavy foot. If your shifts are below 3000RPMS and you don't gas it on the on-ramps you should be getting better gas mileage than that. I think there could be something wrong if you are easy on the throttle.
my shifts are RARELY above 3000 when im driving city, i always just cruise and stay off the gas as much as possible
im gonna try this TB DIY, my car has 96k and theres probably so much crap in there
Received 2,329 Likes
I'm willing to bet its more dependent upon your driving style and road conditions than the new oil and filter.
I Just Con't Drive 55 Mon
...at $2.50 a gallon for 93 in NJ, I'll try anything to get more miles out of a tank full!!!!....thanks for the tip....I have been a little lazy with my oil changes lately
Does the fuel injector cleaner really helps? I heard that once you use them, you have to keep using them. Also, is the optimal psi for our tires 36? I always had them around 40. Maybe thats why i can feel a lot of cracks on the road..=)
The "old" guy
40 PSI??? Thats pretty high actually. Depends on the tire manufacturer and what typ of tires you have. I have 225/40/18's and I run 34 PSI in them. At 40 PSI, Im surprised your car isnt "wandering" all over the road.... Would wear out the tires in the middle of the treak more also. I occasionally run mine at 36 if I have a long road trip
Liftedoff420: Clean the TB and EGR valve. Both would effect performance and gas mileage. I think if your EGR valve is clogged the ECU would run your car rich and burn more gas. Do a search on the DIY for the EGR valve.
Other ideas would be buying Techron Concentrate for a tank, tire PSI at 34-35, air filter replaced every 30k
The "old" guy
i have 225/45/17s and the other set is 225/50/17s.. what should i keep my psi to be?
TL Q(
Originally Posted by Bxscig
Done bout 500 miles nonstop highway avg speed of 85/90 mph heavy trunk and 2 ppl NYC to Toronto no fill ups.
mugen_kid
11-13-2015 10:38 PM
