AllData Access for Acura 1999-2003
hey all,
i have personal access to alldata, mainly acuras from 1999 to 2003.
(especially since i have a 02' tl-s).... heh
if anyones looking for for something specific, let me know.
mr_min
mr_min
anything with heating issue? i also have an 02 tl-s, and a few days ago, my heat stopped working. the ac blows cold air, and when i put it on 90, the heat blows COOL air.... not hot at all..... i'm freezing my a## off in morning until friday..... when dealer looks at it.. just curious.
thanks
thanks
nothing specific to your problem. a suggestion from alldata is to:
apply heat using a hairdryer to the in-car temperature sensor that is to the right of the steering column - looks like a small vent. see if something is stuck...besides that. they have suggestions for under the hood.
mr_min
mr_min
2400 Watts in a TL...Why?
1 Post
would it be too much to ask what the recalls are for a '99 TL-P?
I bought mine used and I want to make sure all the recalls were addressed when they were announced.
Thanks.
Thanks.
Originally Posted by whatwasthat
what's alldata?
ALLDATA is a cardatabase program. that tells u everything about ur car. like TSB and recalls. Torque specs and alot of other stuff.
Sig Rho's Finest
thanks
thanks
Thanks.
hey, this is what they have:
1999 Acura TL V6-3206cc 3.2L SOHC MFI Copyright © 2003, ALLDATA 8.00
Technical Service Bulletins
Recalls:
Number Date Name
02-027 Sep 03 Campaign - AT Warranty Extension
02-014 Jun 02 Recall - Ignition Switch Replacement
NHTSA02V120000 May 02 Recall 02V120000: Ignition Switch Defect
00-004 Dec 01 Recall - EGR System Warranty Extension
00-004 Aug 00 Recall - Emissions Product Update
mr_min
Recalls:
Number Date Name
mr_min
Thanks.
Thanks.
Initial D
Originally Posted by mr_min
hey all,
mr_min
mr_min
Originally Posted by TunedTL
Could you get the details of moonroof rattle problem of 2000 TLP? I think there is a TSB. Thanks
for some reason the only info on this is for the following:
Under Customer Interest not under Recalls
NOV 2000 : Moonroof - Sqeaks from Moonroof seal
Nothing else for a description.
mr_min
thanks mr_min..... i was to lazy to get a hair dryer ,. so i blew air from my mouth twice, and WA LAW..... heat works!!!!!!!!!!!!
thanks a bunch! you saved me from freeeezing! LOL
woooo!!
i really hope this isn't too much to ask... but if posssible, the torque specs for the wheels and braking system (say the bolts in the brake pad/caliper vicinity) on the 99-03 TL... thanks a lot man!
Tristate Vip Crew
woooo!!
![Thumbs up](https://acurazine.com/forums/images/icons/icon14.gif)
Originally Posted by jleon2516
I know the wheel lugs are 80lbs, and here you go, let me know if this is what you needed.
*imaginery rep points*
2000 Acura TL V6-3206cc 3.2L SOHC MFI Copyright © 2003, ALLDATA 8.00 Page 1
Recalls:
Number Date Name
03-017 Sep 03 Campaign - PCM/Fuel Pressure Regulator Update
02-010 Apr 02 Recall - Passenger Air Bag Replacement
NHTSA02V080000 Mar 02 Recall 02V080000: Air Bag Module Defect
01-030 Aug 01 Recall - Front Seat Belt Buckle Replacement
NHTSA01V166002 Aug 01 Recall 01V166002: Incorrect Seat Belt Buckle Parts
00-020 Jun 00 Recall - SRS/Seat Belt Indicator ON
Recalls:
Number Date Name
Recalls:
Number Date Name
Recalls:
Number Date Name
00-020 is a product update for the front buckles.
If anyone wants vin ranges for bulletin and what not let me know.
I can do vin checks to see what recall and bulletin have been done to your car.
I can get radio and navi codes too.
Originally Posted by PDX3.2TL
anything for the rough idle at every once in a while? I know all we have to do is kill the car and wait a while but it is still an inconvenience. 2000 TL-p
Bulletin # is 01-001. Vin 19uua5....ya000001 thru ya052284.
Hope it helps. They replace the pcm and fuel pressure regulator.
Your car is out of warrant though unless you have a certified.
Pcm by itself is like $1000.
I can run your vin to see if this has been done yet?
9th Gear
'02 3.2tl-s
hey all,
mr_min
mr_min
I'm bringing in my wife's 3.2(37,500 mi) into Morande Acura, Berlin CT for an oil change and tranny fluid flush this Friday. About 2-3 month's ago I noticed that when the car is started, the ventilation defaults to A/C and has to be turned-off manually. Possible you can do a search on this A/C issue?
Last Aug. Morande turned the front brake rotors and installed new pads at 30,000 mi. courtesy of a tsb I had learned about on this forum. What annoyed me was the fact that the service advisor initially quoted me $250 to do the brakes, however when I brought up the tsb the service manager readily complied as wear on the rotors and pads were within specified tolerances. Just want to have my ducks in a row for this Fri. on the A/C if necessary.
Would appreciate your help.
Thanks, Jim
Wiring diagram for the 12v+ power sources in the fake ashtray and the middle console,
2002 TL-S. For some reason they don't work and I can't find a fuse either.
Please.
Masik
Please.
Masik
What's the official procedure from Alldata on bleeding the brakes (99TL) or any year TL for that matter. I've heard several variations ie... start from front left and work your way back to the farthest caliper from the master cylinder, start from back right and work your way to the front, and I've also heard the alternate method- front left, back right, front right, back left. Any help would be appreciated.
Recalls:
Number Date Name
How much longer is the extension for the EGR? 100K miles??
Recalls:
Number Date Name
Hi Mr. Min,
Is there any for 2000 acura tl leaking coolant. such as:
leaking radiator hose at the motor or water pump
leaking head gasket
leaking freeze plug
leaking water pump where it bolts to the block.
thank you
leaking head gasket
leaking freeze plug
thank you
Hi, this is my 1st attempt to ask a question on here & am not exactly sure how to do so correctly so if anyone reads this, I need advice about my '99 acura tl 3.2 it overheated shortly after i bought it used at 88k mi because unbeknownst to me, the radiator was bone dry. I put coolant in it & the resovoir wasnt leaking it never overheated again but now the gasket is leaking so i dont drive it now, lest the head gasket blows which hasnt yet as there is no white smoke or clumps in the oil so long story short can anyone tell me what part i need to replace the sealant? Im not car savvy but am trying my best to protect and maintain my vehicles life since i just got it. Thank you.
SUPRMN84
09-02-2015 11:50 PM
