To all those with aftermarket alarms
How are those aftermarket alarms hook up to the stock OEM alarm ? Which remote do you use ? Does the OEM alarm has to be disabled ? Does your progressive lock still work?
An after market alarm will most likely "replace" the stock alarm. You will end up using the remote of the aftermarket alarm.
Depending on the alarm, most installers should be able to retain this function.
If you're going to get a remote starter in addition, you'll need to supply a "donor" key so the chip can be used to start your car.
The way my Clifford is hooked up I use the Clifford remote only.
When the Clifford is put in the valet mode like when at the car dealership for service. The Factory OEM alarm is working if the door is locked by key. When you open the door with key the OEM alarm is turned off. So with the Clifford alarm operating the red light on the drivers door never works but the Clifford has its own LED light. So the OEM alarm is never armed unless I would lock the door by turning key in lock. The Clifford alarm I have set to autolock & arm itself 90 seconds after the door/trunk is shut.
xsilverhawkx
09-28-2015 06:51 PM
