Alarm going off after installing new battery
Old 02-21-2018, 09:24 AM
Djrx's Avatar
My 2003 TL has not been driven for months. I tried jumping it but the battery did not hold a charge, although the ignition lights did come on but would not start. Took the battery to Walmart to get tested and found out it was dead (swollen on the sides).
Bought a new battery but as soon as I got it connected the ALARM WENT OFF. I suspect this is the antitheft system engaging. I removed the horn relay fuse from the fuse box located in the hood (big black fuse) and then connected the battery. I then try to start the car but no power detected. I assume disabling the horn relay disabled the car?
My question is how do I stop the alarm from going off after connecting the new battery? I tried disabling with the key fob but no luck.
Thanks.
Old 02-21-2018, 09:28 AM
Arkady's Avatar
Try inserting the key and igniting the car real quick after you get the battery in. Turning the car on has turned the alarm off for me - but my experience with the alarm didn't include a batter change, so your mileage may vary.
Old 02-21-2018, 10:10 AM
Djrx's Avatar
So I connected the battery real quick and while the alarm was going off I tried cranking the car as you suggested but it did not start. While I was attempting to jump it with another car (with old battery), the ignition lights all came on but not enough power to crank up. So I can't explain why the car is now totally dead with a new battery installed. Cant figure this out.
Old 02-21-2018, 11:04 AM
Arkady's Avatar
That is real strange. Hopefully someone else here has experience with this.
Maybe let it sit without a battery for 10 minutes or so, then put the new one in and see if it goes off?
2007-TL-Type-S
04-21-2017 01:55 PM
NorCoTL
12-06-2013 02:40 PM
Gunny Highway
07-13-2008 03:08 PM
red99cl2.3
11-08-2004 08:37 AM
copland007
02-04-2002 06:48 PM
Quick Reply: Alarm going off after installing new battery
