ALARM Going off at 12AM???
Old Jan 14, 2008 | 11:27 PM
MOBB's Avatar
The factory alarm is going off for some weird reason... I parked the car on the driveway at about 7pm around 12 the alarm went off for no apparent reason... it was just sitting there i went to go check it out and everything was closed and there was no signs of a break in. I started it and took it around the block. I came back parked it locked all the doors and 2min later the alarm went off again with me standing right in front of the car and so on...... with it being untouched.... I have no idea what to look for.... The panic buttons and both the fobs were also untouched WTF is my car possessed?? i have it now so that the door is slightly open so the security system cant activate.
Everything is all stock there no aftemarket installs or anything owned the car for 7 years first time it has done this..
Old Jan 15, 2008 | 02:13 AM
nollid's Avatar
99 Acura TL
For the hell of it, this has happened to me once, check to make the trunk is closed all the way. You have nothing to lose, I would just go around and close each door and finally pop and close the trunk. :shrugs:
Old Jan 15, 2008 | 04:34 AM
TOTAL~LUSH's Avatar
i have the same issue and i have had it back to the dealership twice paid them over 300 dollars to replace a bunch of door actuators and such in the drivers door, and nothing. then they had the car for a week and said they never could get the car to do it. so i have just dealt with it for the last year or soo. i think i have my problem narrowed down. might be the same for you. try when you lock the door do it manually. now when you push down the knob push it down hard, it will feel like it stops only momentarily and then if you push a little harder and then it will go down maybe an 1/8th inch more. try this and make sure it is down as far as it can go and my alarm hasnt gone off for like months. i think it just needs to have the connection in the door adjusted. i have been too busy to do it myself but one day i will get to it. if this doesnt work then i dont really know. do a search and you might find other things. you can try locking the car with only the key and leave the fobs at home. if it goes off again when the fobs are miles away then it eliminates the fob as a problem. check battery read that it has happened on other types of cars.(low voltage) GOOD LUCK!!!
oh and the only solution if it is your actual alarm is disconnect and aftermarket but you loose memory seats when car is unlocked with different fobs!
Old Jan 15, 2008 | 07:08 AM
philly fresh's Avatar
Its good to be FRESH!!
doesnt relate to this thread but i love your avatar TOTAL
Old Jan 15, 2008 | 09:41 AM
acutee's Avatar
It would be bad if you could activate the alarm with any door open. The factory alarm cannot be activated if doors are opened. It could be something is tabbing into its power line that pulls its current.
Old Jan 16, 2008 | 04:11 AM
TOTAL~LUSH's Avatar
you should see the one i had before but then a bunch of moderators sent me msgs saying to change it cause of this at work rule!!!
Jul 16, 2017 07:33 AM
eastcoastguy
Oct 29, 2015 03:00 PM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
njresendez
Sep 21, 2015 11:23 AM
