Air Intake Sensor
Old Mar 27, 2007 | 12:57 AM
orgnlprankster7's Avatar
08 Civic SI
Air Intake Sensor
does it ever need to be changed? at 104k would it be a good idea? when i pulled it out while cleaning my egr port it had carbon deposits and crap on it, i wiped it off but that crap cant be good for the acuracy of the sensor. any thoughts?
Old Mar 27, 2007 | 01:08 AM
08 Civic SI
#10 is the sensor i asume
Old Mar 27, 2007 | 02:59 AM
01tl4tl's Avatar
Buy a can of throttle body cleaner 3-5$ and spray in there, and open the throttle plate and spray some more. DO NOT USE CARB CLEANER- delicate items
Amazing amounts of buildup on the sealing surfaces
6 seconds each place is the directions, and wipe any dripping carbon/dirt that runs out.
Car will run bad a few minutes as it processes the cleaner thru
Spray clean the screen and metal wire in that area too
Do the battery disconnect and reconnect trick to reset the ecu for this one
Old Mar 27, 2007 | 07:25 AM
08 Civic SI
yea i cleaned ou tmy entire intake manifold when i did my egr, are there any signs it would be going bad. throw a code .etc?
Old Mar 27, 2007 | 08:52 AM
fsttyms1's Avatar
Unless its throwing a code or your car is runnig wrong and you suspect its the bad part there is no need to replace it.
Old Mar 27, 2007 | 07:46 PM
08 Civic SI
alright thanx fsttyms1
SidhuSaaB
May 30, 2020 12:40 AM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
drone619
Jan 26, 2016 07:09 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
