Aftermarket motor mounts
kill you till you die
I'm looking at the mount kits on Ebay with the lifetime warranty. Is anyone familiar with these sets and If they hold up better than the OEM mounts? I figure you can't go wrong with a lifetime warranty, but who wants to keep having to pull out mounts every 20k? The plan is to install an engine damper kit at the same time to hopefully help prevent premature failure. Any input is appreciated.
True, but I do 90% of my online shopping on ebay and normally don't run into quality issues. The OEM mounts don't seem to be sufficient either, or there is another issue causing them to fail. These mount kits sold on Ebay aren't specific to Ebay, many of these parts that people label an "Ebay brand" are the same after market parts many other websites or part stores sell. I should have posted in the original post that these are "MotorKing" mounts, they are sold on may sites if you throw the name into Google shopping.
My brother bought me a set of front and side from rockauto. no vac assistance. During idle, you can feel a SLIGHT vibration, but nothing really annoying (as my two previous cars had soild mounts). However, if i had the money and was to pay for it myself, i would have gone with OEM or try to find some with vac assistance.
Thanks, these are the vac assisted mounts. With the OEM mounts failing so often I'm hesitant to purchase them, especially considering the price difference. These are around $130 shipped for all three with a lifetime warranty. Rockauto sells these as well as Amazon and some other places but there are no reviews.
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
Former Sponsor
If you are looking for a more durable engine mount set you should consider our XLR8 motor mounts:
http://store.excelerateperformance.c.../i-411798.aspx
XLR8 Performance’s Engine Mounts were engineered with longevity, performance and value in mind. Many Acura enthusiasts are having issues with broken motor mounts. These mounts are heavy duty mild steel mounts that have been coated with a satin black finish and improved polyurethane bushings that range in firmness. Controlling the durometer of the polyurethane inserts minimizes engine movement. We offer 3 different durometers of inserts, which are available at no additional cost. When ordering, specify whether you want: Street (62A) or Strip (75A) polyurethane inserts. The polyurethane inserts also have a lifetime warranty.
XLR8, do you feel like the engine damper will help improve motor mount life or is the main issue the design of the stock mounts?
yeedatoy (01-19-2012)
2003 TL-p
iv been running the Ingalls Stiffy ETD for while now, its adjusted to almost maximum preload and dampening stiffness. Engine stays in place with almost no movement, minimal vibrations at idle in D5. One of the best things iv ever done to my car. Id say for daily driving all you would need would be the Ingalls Stiffy ETD on new stock mounts, if you want more get the XLR8 poly mounts along with the ETD.
I wonder if vibrations are an issue with the poly mounts from XLR8?
Former Sponsor
http://store.excelerateperformance.c.../i-389457.aspx
If you want a more durable mount set though our XLR8 mounts would be the best choice. They do have polyurethane inserts so they will be firmer than stock mounts and transfer more vibration but it isn't that much with the street bushings.
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
Yes, the damper will help reduce engine movement, which will reduce stress on the engine mounts. INGALLS makes a good ETD for your vehicle:
2003 TL-p
They are, lifetime warranty. Found em on amazon for the same price of $130 shipped since Paypal is pulling some identity authorization crap thats taking too long! Picked up an Icebox while I was at it!
2003 TL-p
also, if you get the stiffy, make sure you adjust it to a stiffer setting and add more preload. out of the box its basically worthless, it contains instructions on how to adjust it you just need a few big wrenches.
Thread from a while back i know! I hate my stock mounts and I have been reading about aftermarket mounts and a lot of guys say that the aftermarket poly gets all messed up really fast? Its hard to believe it... I want somebody to answer a question for me and tell me straight up if the xlr8 mounts will acturally last me.
AcuraCls6speed (10-15-2012)
Former Sponsor
AcuraCls6speed (10-16-2012)
Thank you for your comment. I am still trying to decide if I want to buy the motorking mounts or your mounts. Hard to decide. I had poly on my ls1 trans am and they only caused vibrations when first put in but it went away within a week or 2. Is this the case with your mounts also? Will there be more noise in my car overall?
Hey everyone. So I have EXLR8 mounts 62A and have some vibration when in D5, well I guess this is expected for aftermarket mounts. Just a question tho... If I buy and install the Ingalls ETD, there will be less vibrations when in D5?
The Ingalls ETD will stiffen it up more, hence more pronounced vibrations. Do a search, as some who have it have reported the extra vibrations.
You can try a custom solution with the EXLR8 mounts, like cutting a piece of softer rubber (than that on the mounts) and placing it on top of the front mount. You don't even need to remove the mount to do this....just the bracket on top. If you got less vibrations with this, then doing the rear will help even more. The oem mounts employ a similar rubber piece to reduce/eliminate vibrations.
There's nowhere really to put a piece of rubber on the XLR8 mounts due to the design of them. You could try on the top but it would be inbetween 2 metal parts so I can't see it lasting long. Honestly if you want no vibration then I do not suggest these mounts. These are a fixed mount made only of steel and the poly bushing. I'd recommend them if: 1 - you like to drive hard and/or 2 - you have no desire to change the mounts more than once. It really wasn't an enjoyable job for me doing the rear mount so I'm happy I bought the XLR8 mounts because I intend to keep this car as long as possible.
Former Sponsor
No it will increase vibrations since it will make the motor move even less.
The main thing is this: the vibration is idle only. Soon as you step on the gas it's the same as oem. If you're a really good mechanic and don't mind changing the mounts every 20-50,000 miles then stick w oem mounts. If you'd rather do it once and be set, I'd highly suggest the XLR8 mounts for your vehicle.
AcuraCls6speed (10-17-2012)
victus1 (10-20-2012)
That's probably Ol Mil's reasoning for the EXLR8 mounts !
Remember the saying about " the straw that broke the camel's back " ???
It's too bad that the bolt's and nut's are rusting !
When my motor comes out to put the new one in im fabricating dog bone style mounts like GM uses on just about every one of their motors to keep the motors in place.
Something like this. Maybe attached to the firewall or something. All i know is our motors need an upper support.
![](http://www.automedia.com/Content/Articles/Images/ccr/ccr20060101em/replacing-engine-mounts_dog-bone-engine-mounts-fwd_09.jpg)
Do the newer gen TL's have an improved design of mounts to deal with all of that thrusting torque ?
I actually cleaned all the bolts and shit up too. They were worse before. Pitch black covere in road grime. That bracket too. I cleaned a ton of gunk up in there. I woulda been ashamed to show it before cause it was plain bad but it's way better now. Still not terrible for an 11 year old Wisconsin car. I'll get her nice and clean.
I've been spraying the mount bolts and other areas in the engine bay with some RustCheck rust preventer since I got the car. My bolts came out as if nothing when I replaced the mounts. They didn't even look bad. I even sprayed each new mount, its bolts, threads and mounting holes before installing it.
Yeah, if ya live in a "rust belt' .....every little bit of extra effort pays off down the road, if there is a next time. Ya never really know if you'll be the next one to work on the stuff. Always good to think positively ! Even if ya don't need to go back in, ya may be helping the next person.....and in the meantime, it just looks better !
Jamus22
06-11-2023 10:08 AM
xsilverhawkx
09-28-2015 06:51 PM
