AEM pulleys VS stereo system
Okay.....I got a big problem. I have both the AEM pulleys and a 12 inch sub and 500 watt amp with a .5 farad capacitor. Are there any gains from the pulleys? Are there any major or highly noticeable side effects? I'm afraid to put them on because of possibility of lower power outage like AC won't be as effective etc. I also want to install my sub. Someone who has the pulleys or has experience with the pulleys on the TL please advise as I am getting ready to install these soon.
Rizzie's the color!
Re: AEM pulleys VS stereo system
I installed a 25% underdrive pulley on my '96 Blazer 4.3 V6 and experienced these side effects (on the Blazer, not me): Alternator doesn't charge @ idle; engine heats up in stop/go traffic; engine temp fluctuates, resulting in replacement of a few thermostats; A/C doesn't cool very well at idle.
On a positive note, it will redline quicker and the A/C doesn't drag the engine down much. I also got a modest MPG boost by about 1/2 MPG.
One more negative: You'll likely have to get a nonstandard size belt unless the idler pulley arm is long enough to take up the slack.
AEM, really does't underdrive very much. They really just focus on
weight. With my Accord and 85 watt headlights I had problems.
But, the TLS has a 15-20 high amp alt, and 30 watt hids, so I doubt
you'll have any problems. My opinion on pulleys is fell good money.
Probably won't make your car faster, but if you're gonna do all the
other mods, then you might as well have these too.
4drviper
09-23-2015 09:00 PM
