AEM Intake install problems ABS, VS, ! lights are on??
Old Mar 20, 2004 | 06:48 PM
My friend who has worked for Acura and has installed many AEM intakes installed one on my Type-s TL and now the VS, ABS, !, lights stay on. The thing is that he hasn't even touched anything that would have those lights stay on. We checked all fuses, etc, connections and they are still on I am going monday to his friend to hook it up to the computer to see what it is but I am curious if anyone else ever had such a problem? Thanks
Old Mar 20, 2004 | 07:09 PM
Pure Adrenaline's Avatar
Dragging knees in
Check the hoses. There are two of them. If the vacuum seal is broken, then the computer will throw a code.
Old Mar 20, 2004 | 07:12 PM
its brand new how can I tell if its broken? I also have the resonator for the water put on.
Old Mar 20, 2004 | 07:16 PM
sc354's Avatar
I assume you are referring to the bypass valve right???
Old Mar 20, 2004 | 07:36 PM
njtls's Avatar
just have the codes cleared...its probably nothing..everytime i install something...(ususally electrical tho) my car throws a code and i just clear it and it doesnt come back...if there was soemthing wrong then it will come back after you clear it
Old Mar 20, 2004 | 07:39 PM
I have a question....Im looking to buy the AEM cai and they told me if i wanted to install it id have to take out the foglight. Is this true cuz if I have to take the foglight out i dont think i wanna put a CAI in my car then. Anyone know if this is true?
Old Mar 20, 2004 | 07:46 PM
sc354's Avatar
not true.
Plenty of members on this forum have the CAI and still have the ability to use their fogs.
if they told you that, I suggest going somewhere else to have it installed.
Old Mar 20, 2004 | 07:48 PM
njtls's Avatar
Originally posted by sc354
not true.
taking out your foglight is a good idea however if you want to get the most out of your intake
Old Mar 20, 2004 | 07:51 PM
sc354's Avatar
it's not worth the extra 1-2 HP maximum. It will totally wreck the front end look of the car. The fog lights, with the HID's and the front grill is what make the TL-S such a sexy car.
Like I said, don't let them remove the fog lights, you can definitely install the CAI without removing the fog lights.
Old Mar 20, 2004 | 10:25 PM
Dragging knees in
not true.
They are talking about the misfitment. When I installed mine, the pipe was too long and the filter was hitting the foglight. So I cut the pipe.
MIKESTL --
I didn't mean that a part would be physically broken. The two hoses attached to the intake pipe are vacuum seal hoses. If these hoses are not hooked up properly, there would be no vacuum seal, and the computer will think that there's a leak. I've read about a few people on the forums running into this problem, and after re-mounting the hoses, the code cleared itself. So make sure that the hoses are hooked up right, and that they are ripped or anything.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
drone619
Jan 26, 2016 07:09 PM
kmarqueling
Oct 3, 2015 01:14 AM
