Advice for a GOOD low profile jack
Rice Patrol
I don't need the best. but I have a decent standard height 3 ton big red jack at the moment and I can't for the life of me figure out how I'm supposed to jack it up with the lip kit with this thing, it doesn't even fit under my drop at the moment. I kind of jerririg it by lifting my ride and kicking the jack
How do all of you with almost zero ground clearance actually jack up your car?
it doesn't seem plausible even with the lowest of profile jacks.
advice please, I want to invest in some good tools for the summer modding season.
btw, my budget for a jack is around 50$ am i delusional to think I can get a good lp jack for that much? I only paid 20$ for my big red so the cheaper the better haha
and second question on this, do LP jacks raise the car higher than standard hydraulics? Mine doesn't get it high enough to fit jack stands (lowest perch) under it. I always assumed I just had a shitty jack but that might not be true.
2003 TL-p
check out Harbor Freight, i have a 3k lb "racing" jack that is low profile. does the job just fine, held up to a few years of use problem free. 50 bucks or so, also look for harbor freight coupons for discounts too.
MechEng
i dont use my stock jack points anymore. i drive up on 2 layers of 2X6s and use the front underbracing as a jack point. is it safe? who knows. havent had a problem yet. car feels more stable than on factory jack points.
Avant Garde Wheels
i used two floor jacks.
1. raise rear by rear tow hook. (non low pro)
2. put low pro jack on one of rear jacking point and raise
3. lower floor jack on rear tow hook move to front side jacking point assuming you've raised the low pro at the rear enough and raise front jack point
4. move low pro in rear to front middle and raise whole front.
5. jack stands.
this was all without wood pieces.
5. jack stands.
Rice Patrol
^that seems like a sound method. You could get a standard hydraulic jack under your rear tow hook even when you were slammed??
Just took another look and it looks like with the rear lip it'll be a tight squeeze
6G TLX-S
Get someone to help you lifting the front bumper as high as possible, then you just quickly shove the low-profile jack underneath the car.
the homemade wood ramps/slabs of wood- are the ticket for getting low cars onto ramps, jacks, shop lifts etc
Had to do it all the time in a shop!
jacking one full side of the car scares me!! (except my car which is very stiff and raises the whole side of car when lifted from front jack point!!)
just lift it from the center point- use whatever boards needed to get some height on lifter pad and support one end of the car with stands
I've gone so far as to put one end of the car on ramps, and lift the other end of the car--- support with stands
Can lift off the ramps from center point and insert stands as needed
B A N N E D
btw those factory jack points are fine with the stock jack (or even on the back of the car, where there is less weight, but as soon as you try to lift the front with them, they always seem to bend...)
Rice Patrol
Thanks guys!
I'm going to be buying another jack so I'll have two jacks I'll have to test out both methods and see which one I like best
anyone have a preference for jack itself?
EDIT: Mods, Any way you can change the title or sticky this or something? There's a lot of really good info on jacking up a lowered car in here
6G TLX-S
No need for steroids.
My car is also lowered. I do the lifting and shoving in all my myself, twice every year when swapping summer and winter tires.
First position the low-profile jack right in front of the front lip. Then I turn my back against the front bumper, and lift the bumper as high up as is possible while kicking the jack underneath the car. Done !
But don't try if you're not up to it.
vampires must have lots of strength.
2006 NBP TL MT6/ 02TL-S
Do a google search & research on "hydraulic floor jacks" Read customer reviews. Damn near all of them are made in China now and customers of all brands (NAPA, Sears, Harbor Frieght, etc) complain about how quickly the hydrualic cylinder goes bad. Many of the cheaper ones go bad with as few as 10 uses. Plus they are not repairable or the repair costs about as much as the jack. Apparently there are a lot of crappy jacks out there.
American made jacks are still high quality, but start at around $300 for 2.5 ton models.
The only getting 10 uses out of one is what happened with the last 2.5 ton jack I bought for $35 at Auto Zone. (made in China) Read the customer reviews ( if available) on any model you are considering. It was an eyeopener for me as I though I could get a good, lasting jack for $75 or something.
I even looked into getting an old American made 2.5 ton jack repaired and that was going to be $165 with only a 1 year warranty. If somebody has a relatively inexpensive jack that has held up to several years and numerous uses, I'd like to know what to buy!
harbor freight is your friend
splurge and get the low profile blue racing jack, or the basic jack
2 ton mini jack works to lift side for a tire change, but get a 2.5 or 3 ton for any margin of safety lifting the end of the car
your head is under the car,, inserting stands,, while trusting the jack,,,
is your life worth another 50 bucks for a better stronger jack?
DO get the warranty!! because every jack is going to fail at some point,,if its going to be used a lot in 2-3 years, its worth it
its nice to walk in with a bad one and walk out with a new unit- no hassle
many race teams carry 2 of the blue ones, in case one breaks at the track, it has a backup
6G TLX-S
^^^^^ Yes, always put stands underneath the car at the other support points. Never trust the hydraulic jack to support the car alone.
Any tips on what to do if I can't jack the car high enough to get jack stands under? My jack only goes to about 15-16" and it's not enough to get the jack stands under the points. Would it be safe to put a piece of wood between the car and the jack saddle or should I just go find a jack with a higher range?
AndrewS
19
03-14-2024 06:59 PM
Soul_Deamon
11-13-2018 04:44 PM
TLDude876
12-28-2016 03:18 PM
brandnewcolony
09-12-2015 10:39 AM
