adding shock sensor to factory alarm
Tri State ViP Crew
i did search on addind a shock sensor and followed the insruction but it didnt work, there is more than 1 yellow/silver dot wire (if anybody know is there a different wire you can use) 03tlp sensor dei 504 thanks
Tri State ViP Crew
Originally Posted by JMAL
ok real quick, i just want you to try something. tap a wire to that line, and sit in the car, arm the alarm. wait like 30+ seconds and ground that wire some where to the body. does your alarm go off? if so you got the right one. if you still have issues, go to the fuse box, but the side that is under the steering column. (lay under the dash). there is a silver box with tons of harnesses iinto it. its right next to the parking brake. there is a harness that is located facing the firewall. its hard to get to. get creative and get that harness off. once u get that off, its very easy to find. the wire is located near the center of the harness..
cool man. let me know if it all works ok. i actually got to that step and the sensor was bad. i havent gotten around to finishing it yet. i am putting one at my headlights and one in the car. let me know if it triiggers properly.
J
J
Tri State ViP Crew
J
J
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
