ABS Sensor keeps on Failing!! NO VSA nor ABS!
Old 02-14-2011, 11:36 PM
MOBB's Avatar
Hey guys so about 6 months ago my VSA would go crazy and turn on and off when not necessary then displaying the VSA ABS ! lights on the dash.
Got the code scanned bad front left wheel speed sensor, replaced it with a quality variant Doorman wheel speed sensor and problem solved.
4 months later my VSA is acting up again, whenever I turn right the lights ( VSA ABS !)go off and stay on until the car is restarted. The lights only go off as soon as I make a complete right turn as in the steering wheel hits the maximum rotation then I lose complete function of the ABS VSA until its restarted. I also noticed that putting it in reverse triggers the VSA to go off for no reason on dry surfaces. Basically if I was to drive 10 000 miles by only going straight or left I would have no problems with the function of the VSA and ABS systems. As soon as a full right turn is made then I lose complete functions of that system. The system still self checks upon start up until a right turn is made.
I get the code scanned again, says "ABS Sensor (speed sensor) failure front left, open or short" ok, so I go down to the local parts store get another abs wheel speed sensor pop it in and NO LIGHTS!!! I can finally turn right!!!. 3 weeks later I'm having the EXACT same problem and the exact same code as the previous 2.
What the hell should I look into now?? Wires look fine no damage tears or rips from the abs sensor to the engine bay!
I forgot how not fun it is to drive in winter with no ABS, especially how bad the TL fishtails over the slightest slipping on the road when braking.
Old 02-15-2011, 05:03 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
did you try a different brand of sensor?
are you as low as your avatar shows?- could be pulling on a wire when turning
Old 02-15-2011, 06:46 AM
totaledTL's Avatar
What about the gap between the sensor & ring- is that critical?
Old 02-15-2011, 11:00 AM
01tl4tl's Avatar
like if the sensor wasnt all the way down and locked?
yes that would be a problem, and something a lowered car might experience- pulling on the wire..
good call total'd!!
also ck for debris-oil-crud in the ring cutouts/teeth..thats how the sensor counts wheel revolutions
Jamus22
06-11-2023 10:08 AM
copmagnet82
4G TL Problems & Fixes
06-29-2016 08:09 AM
MilanoRedDashR
10-02-2015 10:49 AM
polish_pat
09-30-2015 12:22 PM
thegipper
09-28-2015 01:01 PM
Quick Reply: ABS Sensor keeps on Failing!! NO VSA nor ABS!
