Abs light is on. What can it be?
The freakin' cars are possessed by gremlins, I shit you not !
Did the lights go back out.....or did the ABS indicator lamp stay on ?
abs/tcs light on
Hey 1st timer, for shits and giggles....check the fuse labeled "R/C Mirror" (7.5a) which is located in the driver's side fuse panel. Then next check the fuse labeled "Back-up Light" (7.5a). Could be an aftershock of the alternator, as this can create many nuisance problems due to low or fluctuating voltage. It sucks !
01tl4tl (09-19-2012)
and that means its working today because.....
did this involve spinning of the wheels at low speed- under 25Kph with active TCS
ie: uses brake on spinning wheel in pulses similar to ABS active
reset the ECU via clock fuse removal method,,see if it comes back
UB6IB9
That's what i was thinking of!! Could it be that my alt wasn't working properly for a while?
Or because of too many hard accels under 25kkm/h with tcs activated?
UB6IB9
I changed the fuse and the light was still on along with the tcs light.
I changed the tcs fuse and still nothing happened.
As i drove off, both lights shut off!!
did you reset the ecu via clock fuse removal method?
rockyboy
12-06-2022 02:29 PM
mada51589
05-03-2022 08:54 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
