ABS Disk Brake Pump Noise
Guest
Posts: n/a
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
I have a 2001 TL that makes a noise when I first drive it. The sound makes a slight grounding noise for about 1-2 seconds and then it stops until the car sits for a couple of hours. The service department says it is the ABS brake pump adjusting. 2 other ACURA owners that I know do not experience this sound. Any suggestions if this is normal or not??? Thanks
![Post](https://acurazine.com/forums/images/icons/icon1.gif)
Hold up...not understanding you. You hear the noise when you are stopping or what? Please clarify.
'00 White Diamond Perl w/Nav
Wings West Spoiler
Comptech Exaust
Rear Comptech Sway bar
Wings West Spoiler
Comptech Exaust
I think you should take your car back to the dealer. They only make noise when the
wheel(s) are locked. In normal driving condition it should not make such a noise. Take it back to the dealer as soon as possible before further damage.
Guest
Posts: n/a
I thought I was the only one that had that situation.
The noise that you mention, does it happen within the first 20 feet after you start driving? (Only after starting the car.) It is sort of a humming/buzzing noise that lasts for only about 1 second?
I have not taken the car to the dealer to have it looked at. It did not seem to be that bad a condition. Should I take the car in to be looked at?
2001 Laguna Green
100% stock
2001 Laguna Green
100% stock
mada51589
05-03-2022 08:54 PM
