99 Nav said "unformatted hard disk"
My Nav sometimes it working and sometimes it does not. when it does not working, it has error "unformated hard disk,...check with dealer". About 6 months ago, it is not working at all. It always says "unformatted disk...or something like that".
How can I reformat it? or is there a way to get it working again without costing much?
Originally Posted by timmy8151
Your HD is toast. Paul Mooney sells a flash replacement for 99 Nav systems.
Search the forum for "PCMCIA" for all sorts of "how to" information on doing this.
Thanks.
I haven't search yet, but where can I get the navigation files? if get from dealer, how much do they charge do you know?
I live in Tampa Bay, Florida. anyone have files in this region? please share.
Thanks again.
Thanks again.
All,
After searching through the forums, I found the solution.
Go to http://navhelp.com/
and order from there for $135 shipped.
This is the best solution i guess. If you order the adapter and the Flash card, some cards may work some don't. some dealer charge for a fee some can do it for free, but it is a hassle to go back and forth to dealer.
I think $135 is good way to go at http://navhelp.com/.
I am not affiliate with that website and not also advertise for them. I just found it helpful.
I just placed my order, not try it out yet, but i heard other members got from him and it works.
Mister_TL, your problem is same as mine, most of the time the hard drive failed due to extreme heat, shock and so on (rarely failed from unit). order new one from the site above. or you can wait until i got mine working then I confirm with you. or you can go to the website and ask him.
Buying a pre-made unit from Paul Mooney is a sure fire solution. Paul is a reputable seller and you can be sure that the units he sells will work fine. If you have a problem, Paul will help you resolve it.
But many forum members, including myself, have been able to assemble identical units for less than $20. Paul uses the same PCMCIA adapters with 512 MB CF cards that you can buy yourself.
My local Acura dealer loaded the navigation files on my assembled unit for no charge. Not all dealers will do this for free but the files can be found for download on the internet if you're willing to search a little bit. All you need is a inexpensive Compact Flash card reader to load the files.
Do anyone of you guys know how update is his hard disk? I've heard hard disk go up to 2003 but if he's loading them onto the hard disk himself does he have the capability to load 2008+ data?
lowrider
Originally Posted by Midwest
All,
Received the hard drive today from navhelp.com.
It works perfectly.
I think you have to have the Navi 4 digits code for it to work like the Radio code. my navi asked for the code when I put it in today. I did disconnected the battery few days ago.
It works perfectly.
acura, bad, disc, error, hdd, mdx, navhelp, navigation, region, se, tl, torrent, tsx, unformated, unformatted
