50$ tranny fluid change?
So last night I stop on local "Acura Honda Specialist" autoshop i Oxford MA. I asked the how much they charge for changing tranny fluid. Iwas told that it will be 50$. I asked them also what kind of fluid their`re using for it - they said the Honda one. It sound like a dream , so I made app for Friday. After a couple of minutes chating with them I`m positive that they know a lot about our Acuras, so I will give them a chance.
Loving my 08 TLS!
$50 is the average cost for tranny fluid change. I pay that much when I got it done in an Acura dealership. If it is a tranny flush and change, then it is like 100+
For $50 you will get ONLY a drain and refill with the proper Honda spec fluid for our cars
Thats a good start, and if you change it every 15k like the new cars require- its fine
For an 03- I personally would do the 3 times flush method to rid the system of old fluid
Long live your transmission
I remember its not recommended to have a flush and fill. Well my tranny fluid change cost 100 plus cuz it was a flush and fill and I didnt know until the dude started doing it. Oh wells.
I'm a big fat hippo
Originally Posted by MikePA
Honda and Acura do not recommend a flush, only a drain and refill.
Than why does the dealer recommend a transmission flush at 30,000 miles?
Originally Posted by HERB THE HIPPO
Damn....and I thought you knew everything.
I don't know why people don't do a search, or read older threads, before asking a question, either. Some are lazy and want others to do their work for them. Others are illiterate. I can't explain the rest. Sorry.
I trust the wisdom of 5 times trans failure - our Moderator, fsttyms1
He says to do the 3 x method
The system holds 10 quarts total- of which you can drain 3.5
Would you drain 1 quart of engine oil and add 1 new-
call it good and keep driving?
Not a machine hot flush as quickie places do-
the way its detailed here with drain-refill-drive-X3
P.S. Replacing the fluid in the Brake Master Cylinder only does not constitute Brake Fluid Flush. Until fresh new fluid comes out all the bleeders- its a sham!
I'm a big fat hippo
Why would I know why a dealer recommends something?
The Brown dit
With all the problems i have ran into recently after getting a tranny flush from my mechanic in cambridge MA. I will do all that stuff at the dealer from now on. Little expensive....but you can bring the car back if there is anything going on afterwards. I am very skeptical of the acura transmissions so i just rather go to the people that konw them
so like I said I`ll give him a chance!
There could not be a simpler job on the TL
Remove drain plug, add new fluid
drive 5 minutes
remove drain plug
add new fluid
The ATF filler is right there below where the vac line for seafoam is
It says ATF on it!
drive 5 minutes
remove drain plug
add new fluid
It says ATF on it!
What about changing the transmission filters? How many are there and can they be done at home in the garage?
Just got a quote from a shop that wants $160 to change the trans fluid and filters.
Thinking of getting a manual to do it myself.
That shop is full of it- run for your life
There are no filters to clean or change on th eTL transmission
Just the 3qts 3 times drain refill drive drain refill drive method described above
Thats all the manual you need right there! Read above post
WNC Real Estate Sales99TL
I change my fluid every 3rd oil change. Round 10-12K. About 3 qts out then 3 qts in. Cost me a 1/2 hour of time and $19 bucks. You don't have to jack up the car. Just measure what comes out and put that amount back into the filler hole on the top of the tranny. I do replace the crush washer.
Savings=$31.00 plus gas driving to the garage and your time sitting in the waiting room. I use the Honda Tranny fluid.
Drain plug is easy to get to. It's on the drivers side (under tranny) and it sticks out to the side-it's actually a bolt. You just take a socket wrench (don't need a socket-just the wrench) and twist it. Fluid squirts out a few inches to the side and can be hot so make sure your drain pan is placed to catch it. After draining it, you can refill from the top (towards the back of the trans-actually stamped ATF)-17mm socket. Fill using long funnel or turkey baster + short funnel). Very easy to do. No jack required.
mada51589
05-03-2022 08:54 PM
HeloDown
09-08-2015 06:51 PM
