45,000 mile service???
so im at the acura dealship right now, and theyre pressuring me to get a 45,000 mile service. im at 45,500. it costs 422$... is this necessary?
What are they going to do for that?
Originally Posted by Phrosttz0
yeah id like to know, cuz im going to be hitting 45k sometime this winter.
Kris what services do you recommend for 45k?
really?? i just scheduled for my 45,000 for wednesday they gave me this coupon, the whole service will cost me $238
45,000 miles:
oil change change
tranny fluid change
brake fluid
test drive
tire pressure
and some other small stuff
45,000 miles:
oil change change
tranny fluid change
brake fluid
test drive
tire pressure
in verbatim from acura:
1999-2003 Acura 3.2 TL - 45,000 Mile Service
change engine oil and filter
Inspection of the following
-drive belts for proper tension and wear
-fluid levels (top off as needed)
-radiator coolant and hoses
-idle speed and quality
-tire condition and tread depth
-tire pressures
-fuel lines and injectors for proper operation
-ignition timing
-exhaust system
-cold enrichment/false idle
-evaporation emission controls
-ignition distributor and wires
-parking brake operation/adjustment
-crankcase ventilation
-PGM-FI EGR system
-drive axles/cv boots
-suspension condition
-tighten all suspension bolts/mounts
-brake inspection including:
1. brake pad thickness
2. caliper and slide pin lubrication
3. hardware and fittings for proper operation
-replace wiper inserts
-tire roation and balance
-perform coolant serive with genuine honda coolant
-perform transmission fluid service
-using genuine onda ATF
-perform brake fluid flush (including ABS) genuine honda brake fluid
-install BG-44k fuel treatment
complete 45,000 mile service.... $422.00
-tire pressures
-ignition timing
-exhaust system
-PGM-FI EGR system
Half that stuff on the list they pop the hood and look down and say inspected, which you could do youself and save some money
Originally Posted by fsttyms1
Honestly... None. All i would do is keep changing the oil on your schedule, check and replace air filters (all 3) when needed and replace tranny fluid every 50-60k.
thx kris
Honda+Blue=My garage
Originally Posted by pmptx
Cabin air, intake, and ????
mada51589
05-03-2022 08:54 PM
Zonian22
11-14-2015 01:20 PM
asahrts
09-04-2015 05:55 PM
