3.7 manifold on a tl-p
Old May 15, 2013 | 07:53 AM
Stephen00TL's Avatar
Chapter Leader (Southeast Region)
finally got my intake manifold installed yesterday and what a difference it made
Old May 15, 2013 | 09:02 AM
Gabru678's Avatar
Difference how?
An immediate responce?
Or more power low range/Vtech?
And do these have that same intake switch that the TL-S's have?
Old May 15, 2013 | 09:10 AM
A lot more power accross the rpm range especially up top. The ecu must be adjusting to the new airflow because the more I drive it the more power it feels like its making. The butterfly's were left open and I don't feel any loss of torque, in fact it feels like I have more. I noticed a difference right away, now I just need to build a new intake. Not sure what you mean by the switch, if your referring to the IMRC I don't have it hooked up
Old May 15, 2013 | 10:24 AM
RC99TL's Avatar
That adapter/spacer plate may be helping a bunch.
Moving the TB upstream away from the manifold and straightening the airflow is probably adding to the killer manifold swap.
Sweet.
Old May 15, 2013 | 01:53 PM
fsttyms1's Avatar
^ and adding more intake volume
Old May 15, 2013 | 02:23 PM
Sweet.
Yep and along with new manifold being bigger it also is about half the weight and it doesn't get as hit because it is made out of magnesium alloy. I drove the car this morning after washing it and I could leave my hand on the manifold as long as I wanted. On the old manifold I couldn't leave my hand on there after driving down the street and back real quick
Old May 15, 2013 | 03:25 PM
Skirmich's Avatar
Now you need Outlaw Thermal Gaskets + Spacer and your Even more Set. Sweet Install!
Old May 15, 2013 | 03:50 PM
AznWay's Avatar
Who made that adapter for you? ( was Kris ) Look very good, now added MDX spacer an you will heard deep tone in our engine. Also I know how much to mill off your MDX spacer to keep your hood shut.
Old May 15, 2013 | 04:11 PM
Sweet after I finish up a few more things I'll have to get your input on that spacer
Old May 15, 2013 | 05:09 PM
fsttyms1's Avatar
Honestly i wouldnt run the adapter. It will help on TQ but you will sacrifice a little on HP
Old May 15, 2013 | 05:51 PM
Skirmich's Avatar
In the Words of Carroll Shelby:
"HP Sells cars, Torque Wins Races"
Dunno about that but I would use more Torque on the TL specially driving around the city.. The car is fast enough for my Tastes.
Old May 15, 2013 | 08:03 PM
Any idea on how much horsepower you lose
Old May 15, 2013 | 08:32 PM
fsttyms1's Avatar
We arent driving the AP1 S2k where you had to drive it like you stole it to make it go . The TL isnt lacking in city driving (especially with the manual). If you think you need more then the car isnt fast enough for your tastes.
Old May 15, 2013 | 08:40 PM
fsttyms1's Avatar
Not off the top of my head but there was a dyno a few years back where the type-s motor lost a few hp and only gained like 6 lb/ft. Also not sure the clearance with the 09 mani but with the type-s engine i only have between a 1/4 to 1/2 inch at most engine to hood clearance (on the 99-01 body style).
Old May 15, 2013 | 08:42 PM
fsttyms1's Avatar
Cant wait for the 3.7
That is if Acura EVER gets me the crank bearings that are on national back order
Old May 15, 2013 | 09:07 PM
Skirmich's Avatar
I simply dont rev the engine enough to feel the loss of those Little HP not even full HP.. Where I would like more Torque around 2000 and 4000RPM < Which is my Daily Drive RPM.
Old May 15, 2013 | 09:15 PM
I have more clearance than that with the 09 manifold although I dont want to lose any horsepower so I will probably end up not going with the spacer. I have plenty of torque so that is not a problem for me especially only 6 lb/ft
Old May 15, 2013 | 09:16 PM
that sucks wasn't youngone going to give you his because he put his 3.7 build on hold for the turbo accord build?
Old May 15, 2013 | 10:17 PM
AznWay's Avatar
Here some before an after of MDX spacer..
Top pic MDX spacer
Bottom MDX spacer mill down to fit
Even with MDX spacer mill down you can still feel TQ
Old May 15, 2013 | 10:31 PM
looks much better milled down I might get one and try it out, iirc it wasn't expensive
Old May 16, 2013 | 06:58 AM
fsttyms1's Avatar
The auto trans is half your issue, . There is alot more useable power in that range with the manual. But to gain more of both, This is why im building a 3.7. I gain a ton of TQ AND gain HP.
fsttyms1's Avatar
Old May 16, 2013 | 06:59 AM
Naija'sTL's Avatar
Geez, you guys are making me sick. I'm finally getting around to installing my 03 TL-S manifold, and seeing the 3.7 makes me want to upgrade again!
Guess I have more work to do, haha.
Looks really good Stephen.
Question: Is your butterfly stuck open because the throttle cable is taut?
Old May 16, 2013 | 07:27 AM
fsttyms1's Avatar
I wouldnt waste my time on the type-s, i would upgrade to the 09+
And what butterfly? The throttle body? It is no different than stock, he is using the stock cable bracket. If it was stuck open then he wouldnt be able to drive.
Old May 16, 2013 | 07:54 AM
Naija'sTL's Avatar
Thanks for the quick reply. Yeah, Stephen said the "butterfly's were left open." I thought it may have been due to the length of the spacer and the increased distance of the TB from the Manifold causing the cable to be stretched.
Old May 16, 2013 | 08:17 AM
Karanx7's Avatar
Unregistered Member
He's talking about the IMRC flap thing inside the intake manifold. The stock ECU works only in OPEN or CLOSE position, so the flap won't work correctly (it is made to handle a variable open to close signal).
So instead of leaving it closed and losing HP and gaining low end TQ, it is better to leave it open and gain HP and lose a little low end TQ.
Even with it open the low end TQ is still better than stock, just not as good as it could be.
Old May 16, 2013 | 09:27 AM
Fsttyms1 and karanx7 are correct I left the butterfly valve inside the manifold open because if you leave it closed you lose power up top. I haven't felt any lose in torque and it actually feels like I have a lot more. I was going to do a type s manifold but realized I can gain a lot more with this one plus it's lighter and doesn't get as hot. I should be building a new 4" intake soon and I'll post pics once I get it done
Old May 16, 2013 | 09:40 AM
Thanks and defidently get the 09 manifold and then get a set of ported runners. It makes a big difference
Old May 16, 2013 | 09:46 AM
Karanx7's Avatar
Unregistered Member
Right, you will still gain low end TQ over the stock Type-S manifold. But you would gain EVEN more if the flap was working. I'll try to make a module that can control the flap when I do this mod (the flap will still only work Open/Close, but better than nothing). I think it would be impossible to get the flap working with a variable signal.
Old May 16, 2013 | 09:57 AM
That sounds good especially since some people are saying the types IMRC can't operate the butterfly's and others are saying it can. I wouldn't mind a little more torque in tHe low end as long as I don't lose power up top. Once you do this mod you wont regret it
Old Jun 15, 2013 | 05:24 PM
the hood just barely closes with the 4" intake, a local member helped me build it from one of the UBI airaid kits with a k&n 4" filter. He had his computer plugged into the car and when we were driving it was reading that the air coming into the intake was only 10 degrees warmer than the air outside.
Old Jun 15, 2013 | 06:26 PM
Naija'sTL's Avatar
Looking good, Stephen!
Any thoughts on making the intake a CAI? Did you guys try that already?
Old Jun 16, 2013 | 12:36 AM
No plans on making it a cold air intake, It rains a lot here and the roads build up water bad every time I drive through a rain storm there is water down in the area where the intake resonator was. I might try to run some tubing from the front bumper up near the bottom of the filter and see if that lowers the temperature of the air coming into the intake
Old Jun 16, 2013 | 05:42 AM
tOny3's Avatar
Have you thought about making a custom intake with a velocity stack? I think you should go that route, I'm sure you'll get gains, not to mention the awesome sound it makes. Friend made his own and sounds like he's boosted but he's all bolt ons!
Old Jun 16, 2013 | 09:56 AM
BigKeef's Avatar
try Comptech cold air box intake? It's a mid filter ice box, won't hydro lock.
Old Jun 16, 2013 | 10:01 AM
If it had 4" tubing I would
Old Jun 16, 2013 | 10:02 AM
Thanks I might have to look into that.
Old Jun 16, 2013 | 03:16 PM
tOny3's Avatar
Here, already looked it up for you.
It's made by Blox also so you know it's quality, 4" inlet to the TB and a 6" outlet with filter and stack.
http://bit.ly/16vT7cc
Old Jun 16, 2013 | 07:12 PM
Thanks I might order one of those soon
Old Jun 20, 2013 | 02:21 PM
the-G-ride's Avatar
Mind sharing where you got that adapter from and where I can get one? i've been wanting to put a 3.7 manifold on forever but I heard the p2r adapters were shitty and didn't seal properly.
Nice intake too. I was thinking about relocating the battery to the trunk and running a 4" intake through the headlight case. Although i'm not sure there would be any gains, plus im pretty sure it won't look good but I won't know til I try. I have an extra headlight layin around, so what the hell
