3.2l misfire
Old Mar 8, 2017 | 03:14 PM
WEEN1E17's Avatar
4th Gear
3.2l misfire
Hey guys, I have a 2003 TL Type-S that misfiring at random cylinders, usually at initial start up, the check engine light, vsa light, and the traction control light goes off. Also when I let it idle for to long these lights will also come on? any help? Replaced ignition coils but that didn't help.
Old Mar 8, 2017 | 03:25 PM
Karanx7's Avatar
Unregistered Member
Welcome to AZine. What's the CEL codes? I don't think the VSA should come on with a misfire, might be something more.
Old Mar 8, 2017 | 03:34 PM
WEEN1E17's Avatar
4th Gear
Hey its P1399 I believe misfire at all cylinders
Old Mar 8, 2017 | 03:35 PM
WEEN1E17's Avatar
4th Gear
and Thanks!
Old Mar 8, 2017 | 05:33 PM
Karanx7's Avatar
Unregistered Member
Hmm, if that's the only code then definitely tackle the misfire first. What are the condition of the spark plugs? Are they NGK?
Fuel injectors on these cars usually don't have problem, but that could also be a culprit.
Old Mar 8, 2017 | 05:39 PM
WEEN1E17's Avatar
4th Gear
I think they are denso. And when I idle those 3 lights come on. (sometimes for a long time, sometimes when I idle tor a short time)
Old Mar 10, 2017 | 01:04 PM
sysuleman's Avatar
No P301-306?
Old Mar 10, 2017 | 06:46 PM
Iggy's Avatar
Probably needs a valve adjustment
Old Mar 10, 2017 | 06:53 PM
sysuleman's Avatar
Usually you'd get the P301-306 if that was the case.
Old Mar 10, 2017 | 07:20 PM
NGK > Denso.
