2nd throttle body wiring issues
Old Oct 6, 2022 | 10:27 PM
Keith johnson's Avatar
can anyone help with a VSA issue i am having on my 01 acura TL after swapping engine for 02 TL type s motor the checking engine light keep coming on, i am not using the 2nd throttle body since i do not have the wiring for it, can some tell me how to fix this problem
Old Oct 7, 2022 | 10:58 AM
Originally Posted by Karanx7
If he has the Type-S ECU and cluster, then he will have issues with the VSA light unless he also swapped the ABS/TCS module for a Type-S ABS/VSA module. He'd also have to swap to a VSA type ABS pump, and potentially different brake lines. For the IMRC connector, he could source a IMRC controller from a Type-S too. He would then need all the Type-S dash and engine harnesses.
Or just use his original TL-P ECU and throw out the VSA throttle body.
Keith johnson
Aug 23, 2022 12:46 AM
velvethammer
Jun 1, 2016 06:57 AM
MiaQbn23
Jul 10, 2014 08:11 PM
jaw5983
Jul 1, 2013 08:48 AM
Oakroadsteve
2G CL Problems & Fixes
Mar 7, 2011 11:39 AM
