2nd intake resonator removal!!!
#121
Boomer SOONER
Originally Posted by slikz
Well just last night I removed the resonator that was behind the bumper. It was kind of hard cause I didn`t have the right tools, especially for the second bolt, it was a bietch taking it out. But I managed and I got it out
I just came back from a drive right now, and wow, the TL sounds like a beast beneath all those resonators. I love the sound!
#122
I have tried the duct tape method (2 layers) with the hum present at idle. The duct tape was still intact when I removed it - no sign of it wearing out.
I've been reading the replys and would like to give my $0.02.
I believe that the hum is related to the length and diameter of the tube between the throttle body and air intake. The after market CAI's eliminate the hum by optimizing the tube diameter and length.
Some hair-brain ideas I have would be to retrofit some kind of plunger, which operates on engine vacuum, that would seal off the small resonater at higher rpm's and open up at lower rpm's. Think of this as a very thin hockey puck connected to a vacuum operated plunger that operated vertically directly above the small resonater. This would allow the small resonater to eliminate the hum at lower rpm's and seal off the resonater at higher rpm's.
Another hair-brain idea would be to fabricate the plastic tube between the throttle body and air intake with a 3" or 4" diameter PVC pipe with rubber adapters (secured by band clamps) to connect to the air intake and throttle body and with the required tubes to connect the vacuum lines. The slight bend required could be done with a heat gun or with a longer rubber adapter. This method would be copying the after market CAI tubes with a PVC version.
Comments?
Comments?
#123
hmmm.. the first idea seems to make sense about the small resonator. and the second idea is pretty crazy since it seems like youre suggesting us to replicate an aftermarket air intake system.. which doesnt seem too bad since we're not gonna be spending over 200 dollars for the real thing. BUT sounds like a time-consuming crazy task! i guess it wont hurt to try.. but how the hell do i make the distance long enough when the airbox cant really be moved up forward or around?
#124
#125
hmm.. i see. sounds like a good solution. i have an off day tommarow, i'll take a look and see if it can be done. thanks for the input! hopefully i can think of something to put together.
#126
No He Can't
Originally Posted by fsttyms1
For starters, remove the plastic engine cover (4 10 mm bolts), then remove the air box cover and hose that goes into the intake.you will see the small piece of plastic hanging from the bottom that is what you will be removing (it doesnt look like much but it makes a HUGE sound difference)
![](http://i144.photobucket.com/albums/r196/KSuchdeve/untitled.jpg)
The second red circle here?
![](http://i144.photobucket.com/albums/r196/KSuchdeve/untitled2.jpg)
Or the red circle here which is connected to the other side?
#127
The cover to the air filter. Remove that. then remove the clamp on the TB. Then the rubber tube can come out/off which will gain you access to the small resonator and its clamp you have circled. (the one that goes from TB to air filter) remove any thing thats attached to it to get it out.
Dont be afraid to take things off the car. you can always put them back on
The large resonator is behind the bumper. You either take the bumper off to do that, or get it from underneath. With the TL-P its easier to remove the bumper.
#128
Oh Hullow
how badly i want to show acura this thread... and scream at them for misdiagnosing my stalling problem by blaming on the resonator being removed......... nice cheap mod maybe if it wasnt 30 degrees here in jersey id attempt it haha... good job!
#129
Originally Posted by 03bl AC k CL
how badly i want to show acura this thread... and scream at them for misdiagnosing my stalling problem by blaming on the resonator being removed......... nice cheap mod maybe if it wasnt 30 degrees here in jersey id attempt it haha... good job! ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
AND 30deg???? thats warm out. Put on a sweatshirt, lay on a blanket and go to town.
#130
No He Can't
Wow, I must be an idiot. I can't seem to even get off the stock intake tube for the life of me. Is it really necessary to remove the air filter cover? I guess last time I changed the air filter, I tightened the screws too tight and can't seem to get one of the screws off because it is starting to strip. How do I go about removing the screw that is stripped? Take a Dremel to the head of it or I remember seeing a bit head that can get out stripped screws?
I loosened the screw in picture one, got the clamp off on picture one, but on the other side of the intake tube, there are more hoses and clamps. I got one off, but there is another one that I can't seem to get off. Is taking the air filter cover off going to make it easier to get to the intake and get off the metal spring type clamp that holds on the intake tube (right under the orange clip in picture one).
Any help would be appreciated, but if I can't get it, I'm just going to leave it the way it is.
BTW, what is the "TB"?
#131
Lamborghini Aventador FTW
#132
bringin lead
Just found this thread today, but it looks to date back way before 2005 - did any of you guys ever find a solution? Did you go back "stock?" Still pimpin the hum?
I'd like to try this, but that damn HUM is annoying - and I've never even heard it!!!!
![Yuck](https://acurazine.com/forums/images/smilies/yuck.gif)
#133
The wood god
Just did the mod and it didn't hum at first startup then I took it for a spin and when I put it in park I could hear the hum in full force.
I also had a nice smell coming from the engine.
#134
Again,The hum is the intake itself. thats one of the reasons the small resonator was put on. Its there with a short ram intake too(just not as noticeable)
The smell wasnt cause you removed the resonator.
#136
I just read all 6 pages of this thread hoping a solution was found for the hum.
I was ready to do this tomorrow, but I guess I won't now. I just put in a K&N drop in today. I may just remove the lower resonator behind the bumper and leave it at that. Is there any hum noise after removing that one? I don't want anything much louder unless I step on the gas for VTECH.
I will admit I am not a huge mod guy, but reading this site is starting to brainwash me to do some.
![Butt Head](https://acurazine.com/forums/images/smilies/butthead.gif)
#137
I will admit I am not a huge mod guy, but reading this site is starting to brainwash me to do some.![Butt Head](https://acurazine.com/forums/images/smilies/butthead.gif)
Thanks for the entertainment guys!!!
#140
Nissan Titan in
hmm well i just read the entire thread and was wondering what if you got this piece for the TLS since it doesnt have the resonator hanging from it and put it on a TLP would it fit?
#141
No. they have a larger dia throttle body and VSA
#142
Registered Pimp
so you figure out how to remove the hum yet? or is the hum even that big of a deal. Im going out in a few mins to remove the lower intake resonator and im wondering if i should do the other too. Like will people think my car is a POS because they hear a hum at idle?
#143
#145
Registered Pimp
heres what i think is making the hum after the bottom part is plugged. There is still a little pocket where air can move around with the plug in.
![](http://fc01.deviantart.com/fs23/i/2008/006/3/0/99_tl_intake_by_burnerjunky.jpg)
Im going to experiment by plugging the hole with the pvc cap, but filling the inside of the cap with like hot glue or something that wont deteriorate and get sucked into the engine. Maybe also sanding down the cap to fit the exact contour of the inside of the intake
#150
Registered Pimp
Originally Posted by n1njai
Haha so you guys modded one and removed one correct?
#152
Registered Pimp
Originally Posted by aznboi2424
i think the hum is being caused by the removal of the resonator. because thats what the purpose of the resonator is, to reduce noise.
#153
Registered Pimp
#154
I don't think so. Why would Honda put a huge ass resonator or it just to reduce hum, rather than just redesigning the intake so it doesn't hum. I think it was just meant to reduce engine noise in general.
#158
Originally Posted by kushsmoker
has anyone tried using the pvc piping without cutting it? A longer pipe could possibly work as a resonator but more free flowing
#159
Might as well leave the stock small resonator in it. thats what that one is for
